Euro members, wheel question
Old 03-29-2002, 04:16 AM
Keane Rated R's Avatar
Default Euro members, wheel question
kinda dumb but what is the widest tire size you can put on the stock enkei´s ?
Old 03-29-2002, 06:07 AM
Cosworth's Avatar
Default Re: Euro members, wheel question (Integra Rated R)
225's in the front. 225's in the rear will require 5mm spacer from what I hear from the autoX-ers.
[edit] is that for the 17" ATR rims? what's the width and offset on that?[/edit]
[Modified by Cosworth, 10:08 AM 3/29/2002]
Old 03-29-2002, 06:12 AM
Default Re: Euro members, wheel question (Cosworth)
no, it´s for the 15"´s , I´m thinking of rolling on them this summer and I was thinking of 215 or 225 would be ok
[Modified by Integra Rated R, 3:12 PM 3/29/2002]
Old 03-29-2002, 07:23 AM
DutchITR1689's Avatar
Are you kidding? Stock Enkei (Euro+USDM) is only 6" wide. I won't go further than 205.... Especially S03s, because the 205s are 213 mm wide in real.....
Go for the 205/50R15 or 195/50R15 (a lot cheaper) S-03. You won't be disappointed!!!
BTW Time to update your sig.
[Modified by EuroITR1689, 5:51 PM 3/29/2002]
Old 03-29-2002, 10:46 AM
Default Re: Euro members, wheel question (EuroITR1689)
the sig, already done
isnt 50 to high profile for exceptional handling? anyway.. I´d like more oppinion on this.. it´s 1:1 right now
Old 03-29-2002, 11:35 AM
py1188's Avatar
I think it would be kinda awkward mounting anything wider than a 205/50 on the stock rims. I would think the tires would bubble out and would not be optimal performance wise. 225/50 would fit in the front, and teh rear with a spacer, but I bet it would rub at full turn.
205/50 is the way to go
Old 03-29-2002, 12:24 PM
Default Re: Euro members, wheel question (py1188)
what kind of tyres are recommended?
Old 03-29-2002, 12:57 PM
Cosworth's Avatar
you asked for the widest tire size you can put on the stock enkei´s.
so I initially thought it would be for a track. my bad. For daily driving, go w/ 205/50/15's. Falken Azenis are advertized as 205/50/15's, but it seems they are more like 215/50/15's or so... and they fit stock 6" rims.
Tire rec = S-03, P-zero, Azenis, A032R, Re730, etc, etc, etc... just depends on what your budget is.
Old 03-29-2002, 02:38 PM
what brands are those? Azenis are Falken.....
Old 03-29-2002, 02:42 PM
Luke's Avatar
Yeah you would be in a mess with sidewalls using 225!!!! go for stock, 205 if you must
Old 03-30-2002, 09:47 AM
Default Re: Euro members, wheel question (luke)
how good are Goodyear F1?
Old 03-30-2002, 10:07 AM
Luke's Avatar
Sounds fishy!!! i rate the Yokohama's and the stock Bridgestones
Old 03-30-2002, 10:09 AM
Jason's Avatar
S03=Bridgestone
P-zero=Pirelli
A032R=Advan
RE730=Bridgestone
for daily driving, I'd recommend and of the above minus the Advan's, as they are an R compound tire and designed for track use (although there are people that use them for daily driving)
I'd also recommend the Falken Azenis for a good compromise w/ performance and tread wear...205-50-15
Old 03-30-2002, 10:21 AM
Default Re: Euro members, wheel question (Jason)
thanks for all the clarifacation and info!
I will check prices after the weekend
Old 03-30-2002, 06:12 PM
New User
DC2#309's Avatar
you should still be allrite with 215/50, we even put 215 RE540S semislick on our stock wheels. But putting 215 tyres with a really really stiff tyre wall such as RE540S is not an easy job though.
fulvus49
06-19-2008 03:49 PM
Johnny.
Honda Fit
05-29-2007 02:17 PM
pyitrboy
01-10-2007 05:11 PM
bad-monkey
06-10-2003 07:36 AM
civicboy95
07-18-2002 10:00 AM
Quick Reply: Euro members, wheel question
