difference in WHP with wrapped/not wrapped header
Re: difference in WHP with wrapped/not wrapped header (comptechgsr)
No one really uses wrap anymore; everyone gets theirs coated because wrapping the header usually results in the header being damaged over time.
Two comapnies that do good jobs coating the header is JetHot and HPC. do a search and you should find plenty of information
The advantage of wrapping the header is not really to gain hp but to lower the tempature in the engine bay and prevent heat deterioration to hoses and electrical wiring.
Re: difference in WHP with wrapped/not wrapped header (onyx00)
i have the dc sports and i'd have mine for two years, never had any problem. i only did this reduce heat with the engine bay.
Re: difference in WHP with wrapped/not wrapped header (SANBST)
Most of the difficulty comes in a daily driver being wrapped & living in an area with lots of rain or snow - the header wrap (unless done VERY well & painted with their protective paint) can hold the moisture causing rusting problems.
Hope that helps. Consider wrapping the intake if it's aluminum or plastic to keep the intake air cool.
[Modified by BudMan, 7:12 PM 2/10/2002]
-what do you mean the header being damged over time?
96hatchBoy
10-26-2012 09:14 AM
