Car won't start up strong. Sounds like it's going to die..
Sometimes when I start my car, it won't start up strong. It sounds like as if it's going to die and then starts up. Anybody know what could be causing this?
Re: Car won't start up strong. Sounds like it's going to die.. (Type-Rizzle)
Do you allow enough time for the fuel pump to prime? I thought my R had a problem and needed to be taken back the dealer to be fixed. I found out that you need to turn the key to the second click and you need to leave it there for alittle bit until the Check engine light goes out. I think the fuel pump needs time to pressurize the system. Maybe that is why your car can't start up becuase it lacks the nessary fuel pressure in the beginning.
Re: Car won't start up strong. Sounds like it's going to die.. (MISFIT)
my itr motor will not start up on the first crank, i have to crank it once for a split second, let it sit for 2 seconds, then it turns over on the second try. go figure.
Re: Car won't start up strong. Sounds like it's going to die.. (PyR01-0347)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyR01-0347 »</TD></TR><TR><TD CLASS="quote">Do you allow enough time for the fuel pump to prime? I thought my R had a problem and needed to be taken back the dealer to be fixed. I found out that you need to turn the key to the second click and you need to leave it there for alittle bit until the Check engine light goes out. I think the fuel pump needs time to pressurize the system. Maybe that is why your car can't start up becuase it lacks the nessary fuel pressure in the beginning.</TD></TR></TABLE>
yep.. you should at least do that.. maybe for a second or 2.. but never start as soon as you place the key inside ignition. other than that, make sure plugs/distr. rotor are in good shape and don't need to be replaced..
Now that I think about it, that may of been the reason why it did that. Just wondering why it does that in the ITR, but not in other cars? I don't think my mother's Acura TL does that.
bringing back from the dead*
is this necessary to wait a few sec to let the fuel pump prime up? theres got to be something else behind it. my 4 runner does not require a wait time nor does my other cars....
