OEM bearings with Aftermarket rods?
Old 09-09-2004, 10:48 PM
itralex's Avatar
Default OEM bearings with Aftermarket rods?
I'm gonna be buying some OEM bearings from Len sometime soon
i just want to know since that i am swapping rods will the size of the bearings change cause the rods changed
Old 09-09-2004, 11:41 PM
110 South's Avatar
Default Re: OEM bearings with Aftermarket rods? (HypeR1004)
Yes,
You will have to measure the inner diameter of the rods big-end so you can size your bearings accordingly.
-Brandon
Old 09-10-2004, 05:19 PM
itralex's Avatar
Default Re: OEM bearings with Aftermarket rods? (110 South)
once measured, how do i know which OEM bearing to use?
Old 09-10-2004, 05:44 PM
Pondus's Avatar
This might be useful info : https://honda-tech.com/zerothread?id=715490
Old 09-10-2004, 05:56 PM
DavidR's Avatar
Default Re: OEM bearings with Aftermarket rods? (Pondus)
Yup, just the post to refer to. I would recommend ONLY honda rod and main beaings, as you can get exactly the tolerance you want! Sure, other bearings cost less, but you don't see the V8 guys resizing thier rods and mains to fit those, now do you? (ie. Eagle and many other manufactures fit V8 rods and cranks to fit Honda bearings).
Old 09-11-2004, 03:16 AM
Nvious R's Avatar
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: OEM bearings with Aftermarket rods? (DavidR)
nothing beats OEM stuff (Bearings, seals, gaskets, blah blah)
bnmm
01-09-2011 08:32 PM
b20vtech
02-21-2006 07:57 PM
itralex
09-10-2004 06:12 PM
S88HON
07-22-2004 10:48 AM
EKweezy
10-08-2003 10:09 AM
Quick Reply: OEM bearings with Aftermarket rods?
