Battery Tie down problem with lightweight battery?
I recently picked up a T1R lightweight battery, and that thing is tiny. Anyway, my battery tie down(I guess its the stock one as far as I can tell) wont screw on tight enough to secure the battery. Anyone else have a similar issue and what did you do to secure the battery?
Re: Battery Tie down problem with lightweight battery? (RTW DC2)
for a clean fix use a stack of small washers on the metal tie down rods then put the nut on top of them to tight the battary down.
Re: Battery Tie down problem with lightweight battery? (Rboosted717)
Man you guys are Ghetto Take the existing battery tie-down brackets ( the metal rod) and measure the length you need to shorten the rod. Mark the spot on the lower end of the rod (the curved end), add about 3/4 of an inch to the marked spot and cut the curved end off. Stick the non-threaded end in a vise and bend it to match the factory curve. Reinstall. Now you have the tie-down without the threaded end sticking up 2 inches above the battery. YO
Mattj
[Modified by Dropspeed, 9:20 PM 1/25/2003]
Mattj
Re: Battery Tie down problem with lightweight battery? (sackdz)
If you want a pretty set up get one of these brackets from Holley. Please excuse the picture size.
[Modified by DB1-R81, 9:25 PM 1/25/2003]
Re: Battery Tie down problem with lightweight battery? (DB1-R81)
That looks like a nice setup but I don't think it can work with the T1R battery since the terminals are at the top of the battery.
Re: Battery Tie down problem with lightweight battery? (NunRacer)
You gotta do it this way man. Ignore the rust, leaky taillights. I bought the car this way, and haven't had the chance to fix that part up yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB1-R81 »</TD></TR><TR><TD CLASS="quote">If you want a pretty set up get one of these brackets from Holley. Please excuse the picture size.
[Modified by DB1-R81, 9:25 PM 1/25/2003]</TD></TR></TABLE>
Is it me or does his OE front bar look like its hollowed out? WTF?
New User
Re: Battery Tie down problem with lightweight battery? (skafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">
Is it me or does his OE front bar look like its hollowed out? WTF?</TD></TR></TABLE>
its just you
its just you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">I recently picked up a T1R lightweight battery, and that thing is tiny. Anyway, my battery tie down(I guess its the stock one as far as I can tell) wont screw on tight enough to secure the battery. Anyone else have a similar issue and what did you do to secure the battery? </TD></TR></TABLE>
Are you sure you are turning the nut the correct way?
Re: Battery Tie down problem with lightweight battery? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
Are you sure you are turning the nut the correct way?</TD></TR></TABLE>
I dunno, you are the one that plays with nuts so you tell me lol
I have the T1R battery and have experienced no such issues.
the two battery tie down threaded posts have enough length/thread to tie down a battery probably another size down!
Re: Battery Tie down problem with lightweight battery? (98type_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98type_r »</TD></TR><TR><TD CLASS="quote">
its just you</TD></TR></TABLE>
No, It is hollowed out. I'm pretty sure thats a comptech strut bar.
Re: Battery Tie down problem with lightweight battery? ([VTEC]TL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [VTEC »</TD></TR><TR><TD CLASS="quote">TL]
No, It is hollowed out. I'm pretty sure thats a comptech strut bar.</TD></TR></TABLE>
Just checked comptech's website and their bars look almost like OEM. The one that is hollowed out wasn't on their website. Weird. Wouldn't that make it weak?
I dunno, you are the one that plays with nuts so you tell me lol </TD></TR></TABLE>
******, I'M GOING TO BURN YOUR CAR.
