B18C5 - oil and antifreeze mixing
Old 02-02-2015, 07:08 PM
subtlecuddle's Avatar
Default B18C5 - oil and antifreeze mixing
Hello Type R forum. I own a vehicle with a Type-R swap in it. I have basic bolt-on mods, and some oil burning at high rpms. Minimal oil smoke at startup, so no valve stem seal leakage. A recent compression test revealed good compression in all cylinders.
I recently popped my oil cap and looked inside and noticed some "milky substance" under the oil cap. Looks like oil and antifreeze mixing. I drained the oil, but it looks unaffected. Has anyone seen this before? I have a non-OEM pcv valve in there, other than that the motor is pretty much stock. I am guessing that it's either the head gasket or maybe the oil cooler is starting to fail? Has anyone experienced an oil cooler failure before?
Thanks in advance for any comments or suggestions.
Old 02-03-2015, 10:37 AM
Tight-R's Avatar
Default Re: B18C5 - oil and antifreeze mixing
That's from condensation, not from it mixing with antifreeze. Very common problem with cars like an ITR that don't get frequent use. Many other reasons for it as well. Link to a little reading below.
What is this white milky stuff under my oil cap?
Old 02-03-2015, 03:36 PM
Thanks for the reply!
Old 02-03-2015, 06:42 PM
B16EJ's Avatar
The only time I saw this on my itr was when the head gasket blew 1000 kms after a complete tear down and rebuild, the head gasket was defective.
Old 02-05-2015, 04:39 AM
Tight-R's Avatar
So just a little milky sludge was under your oil cap when you had a BLOWN head gasket?
Old 02-05-2015, 06:36 PM
cheapskate's Avatar
I had the breather box off my gsr last year, it looked exactly the same as yours. Still racing it.
Old 02-06-2015, 08:38 AM
Premium Member
BigJ74's Avatar
I have also heard that this is a sign of a failing or failed head gasket. Just from reading a bit through old posts
Old 02-07-2015, 03:02 PM
highroller54's Avatar
Water in the oil, could be condensation or the start of a leaking head gasket. B series arnt normally bad for doing that like some motors from Condensation
Old 07-20-2015, 08:20 AM
Joseg4188's Avatar
I have the same problem with my itr swap oil and anti freeze mixing what can I do to clean all that out the block
Old 07-21-2015, 09:52 AM
B16EJ's Avatar
No the entire valve cover was caked underneath with the gross milky
Stuff
Old 08-04-2015, 08:52 AM
Thanks for the replies everyone, I just need to drive the Type-R more to get rid of the condensation !
jonyi27
04-21-2014 11:55 AM
saemoonyang
07-15-2009 08:38 PM
SOHC_MShue
07-25-2005 10:36 AM
Jeff
04-18-2005 06:23 AM
98cwitr
04-27-2004 01:34 PM
Quick Reply: B18C5 - oil and antifreeze mixing
