adjusting the drivers door??
well as some of you know my R has a couple nice dents on the drivers side door. i was wondering if anyone knows how to adjust the door so that i seals better. during hard rain the car leaks like crazy. im sure there is a way to do this, just not sure how. thanks
andy
andy
Re: adjusting the drivers door?? (andrewasf77)
From what I just read in the Helm manual, you can adjust the door IN and OUT by loosening the door mounting bolts, and you can adjust the door foward/backward up/down by loosening the hinge mounting bolts. Unfortunatly I do not have scaning material to show you the graphics.
BTW you can also adjust the door catch In/Out up/down by loosening its mounting bolts
ttt
my leak seems to be a result of the same problem.. i need to adjust it in i believe..
anyone have any more info on this?
Re: adjusting the drivers door?? (hungsteR)
When your car's leak due to the door, where does the water collct at?
Re: adjusting the drivers door?? (mstewar)
mine collects in the floorboards on the driver's side...
Are you sure the gaskets/ door seals are in good condition? Make sure that they are not torn or unclipped first before you go and start unbolting things
Re: adjusting the drivers door?? (Bbasso)
tha Big EZ
12-04-2003 10:47 AM
