'96 Spec JDM
#26
re: '96 Spec JDM
On my SI, I've primed/painted/undercoated all inner fenders, inner trunk sides and now working on the interior parts of the car. I've started with the drivers' door - removed the panel, cleaned off dirt, sprayed 3M Moly-Lube and will do a second coat soon. Then onto the rest...
It never ends but at least you know you are preserving a real beauty!
*I know this may be blasphemy for some, but IMHO yes there is a difference between the R and the SI, but it's not that big a difference in daily driving unless you're really pushing it and I've even driven a couple of nicely sorted and upgraded SI's that were better than a standard R. *awaits flames and righteous ban…*
#27
re: '96 Spec JDM
Great work!
Glad to see someone paying attention to the important aspects of maintenance and rust protection.
#28
re: '96 Spec JDM
I have an OE muffler in my loft, I need to get the flange re-welded and the previous owner has had an extension welded in. I guess they were bolting it to an aftermarket/custom mid pipe and was a different length to the OE pipe.
Having said that, the Tanabe is of very high quality. On the other hand it's kinda loud and not the best looking exhaust, not ugly by any means though.
#29
re: '96 Spec JDM
Nah, it's pretty much the same as I got it back in 06 T. Just do maintenance and keep an eye out for any corrosion, but so far so good(touch wood). Daily driver in all that time too and I use it for work. Yep. It's a surprisingly roomy "van" when the need arises.
This is an old pic(and my avatar);
Handily shows the best of the local weather. Sure you know that one yourself. Since then I slapped on some clear side repeaters and I sourced some grey OEM wheels, to replace the ones that were nicked on the boat from Japan(I ended up with the previous owners Civic Type R ones wearing snow tyres) Though I went for UKDM ones as 1) I'm a cheap so and so and the tyres are cheaper and 2) on some Irish roads a moon buggy would be a better bet so the bigger JDM ones would be more prone to damage.
EDIT here's a more recent pic from last week of the oily bits.
All standard really and not looking too bad for 160,000 Kms on the clock. Doesn't use a drop of oil either. They're a scarily reliable oul beast. The only non service parts I've done has been a distributor rebuild which cost less than 80 quid.
You have it well covered. Other areas I'd fire wax into are into the bonnet leading edge and the bottom of the boot lid. If she has a tendency to leak from the rear lights as they often do any moisture ends up in the spare wheel well and then by condensation on the glass into the boot lid. That's what I found anyway when one year I ended up with the makings of a carp pond in my boot. You can sort the leaks with new rear light gaskets from Honda, or better yet get some of the aftermarket ones made from much thicker neoprene as the originals are as thin as a catwalk model. Here's a link to a lad selling them. I dunno what quality they are and no doubt there's someone closer. Californian owners are reading all this as if it's in a foreign language.
Mine sits outdoors in the Irish weather so it pays for me to be paranoid. On that score T make sure you have security sorted as these cars need good security layers like a fish needs water.
P.S. No leaks here so far.
#34
re: '96 Spec JDM
I thought I'd share some more pictures of the undersealing/waxoyling that I've done. I was very pleased to see such clean sills when I removed the skirts. Some minor bits of surafce rust here and there but that's all been ground back to metal, treated and then undersealed/waxoyled. Same goes for the rear underside and arches.
Really clean behind the bumper too!
#39
re: '96 Spec JDM
Thanks, man.
Trying to get the big important stuff done first. I've now done a full service and made a good start on the undersealing/waxoyling.
No major plans for the car but I would like to get an OE rear upper strut brace and replace all the disks and pads with OE Honda, replace the RTA bushes and get my OE muffler on.
#41
re: '96 Spec JDM
Refurbished the battery stay. Also cleaned up the hooks/bolts and fitted new stainless flange nuts.
#42
re: '96 Spec JDM
Front bumper off and inspecting the body for corrosion. Only some light surface rust found. Ground it down with a wire brush attached to a drill. I then used some Hammerite anti rust stuff. Let that dry out overnight and the next day began applying Underseal with added Waxoyl. Also applied it to the bumper bracket as I had no black Hammerite - it seemed silly to take the bumper off again just to paint the bumper bracket with Hammerite instead of using what I had available.
Part of me thinks that I should have sprayed it in the original Championship White finish. I guess I could go back in there at a later date and spray it. Opinions?
#44
re: '96 Spec JDM
With all the work you are doing on this sweet ride, please fix the mismatched tires with the grippy ones in front before you oversteer and crash this thing. At least put the grippy ones in back until you can match a set. Otherwise very nice car and work you are putting in.
#46
re: '96 Spec JDM
Thanks. That might work in the States but over here it would get all mucky and look not so clean. I think the black is more discreet. You're not going to see that it's underseal unless you get up close. I'll take a picture tomorrow once it's all dry.
#48
re: '96 Spec JDM
I plan to replace the rears with the same as the front - Bridgestone Potenza RE002 195 55 15.
#50
