Hub bearing
Hub bearing
Here's the story, i got a JDM ITR 5 lug conversion and my hub bearing went bad. So i cant seem to figure out, can i replace this with a USDM bearing of do i have to find a JDM one.... Or will a 99-00 CVR bearing work? I need as much input on this as possible. Thanks Honda-tech!
Re: Hub bearing
Which hub, front or rear?
Rears are probably the same.
I know the ITR and 99-00 Civic Si part numbers for the front are the exact same so I ordered mine thru a local Honda dealership but then again, I have the USDM knuckles.
For some reason, I remember them being the same bearing from jdm to usdm. Hopefully more will come in to clarify.
-Jarrod
-Jarrod
Re: Hub bearing
-Jarrod
-Jarrod
Sorry, it's the passengers side front. I can't figure this out...
Re: Hub bearing
yeah its a possibility you'll need the cr-v bearing since they use same hub as the jdm look at the part numbers of the hond-crv bearing and an itr bearing. Keep us posted its good to know
Re: Hub bearing
Just send the car to the mechanic and tell them you have a problem with your bearing. I have this problem before so it will save you time, problem, money, and frustration. If you not sure about it send it to the mechanic. I had problem with my bearing and it was horrible and good thing that my mechanic biddy help replace it with new one.
Re: Hub bearing
NsX_CrX
06-14-2006 09:16 PM
Redline96LX
10-19-2005 03:19 PM
boostedcivicsir
07-02-2003 01:44 PM
