37.5K mile service... Worth taking to Acura?
Old 01-03-2003, 09:06 AM
New User
io_burn's Avatar
Default 37.5K mile service... Worth taking to Acura?
My stupid-*** Maitinence Required light is blinking... Anyway, according to itrca.com this is the stuff that needs to be done:
7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid Levels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
Now, I can check all my fluids and rotate my tires and stuff like that... But how do I check the clutch adjustment and the brakes? Would I be messing up my warranty by not taking my car to Acura to get all this **** done? I figure I'll waste a day taking my car there so the tech can give it a once over, say "Hmm, everything looks good" then charge me $100. (Is that accurate? Or would it be more?)
Old 01-03-2003, 09:10 AM
Willard's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (io_burn)
reset the light and do the work yourself.
Old 01-03-2003, 09:13 AM
New User
io_burn's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (Willard)
Any idea how much they would charge me to do it at Acura?
Old 01-03-2003, 09:15 AM
TsunamiZC's Avatar
500.oo dollars
len
len's Avatar
*ahem* I wouldn't do it. *ahem*
Old 01-03-2003, 09:17 AM
New User
io_burn's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (tsunami_zc)
500.oo dollars
Are you fookin' serious?!?!
Old 01-03-2003, 09:18 AM
vtec.dc2's Avatar
probably $70-110... you could call and find out... i find it improtant to get all required maintanance done, whether you know how to do it yourself or taking to dealer
Old 01-03-2003, 09:20 AM
New User
io_burn's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (vtec.dc2)
I think if it's only $100 or so I'll just take it so I can have the paperwork that says I did all the stuff I was supposed to for the car. *shrug*
Old 01-03-2003, 09:31 AM
pleiades nutz's Avatar
Don't do it!!!!!! I took mine in for its 30k service and spent $500 to have it done....well about a 1000 miles and a month and a half later I found my car being 2.5 quarts low on oil.....wanna know why......cause they forgot to send the "tech" to oil changing school!!!!
Old 01-03-2003, 09:36 AM
B2FiNiTY's Avatar
Do it yourself
Old 01-03-2003, 09:40 AM
disordeR's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (B2FiNiTY)
-deleted-
if i read the thread i would be smart.
[Modified by disordeR, 10:41 AM 1/3/2003]
Old 01-03-2003, 09:46 AM
Larkin W.'s Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (disordeR)
dont do it!! Those every other 7500 mile services are mostly visual and tire rotation any way which is easy to do on your own. Waste of $$
Old 01-03-2003, 09:48 AM
Eva01's Avatar
Bah...save your money and do it yourself. Clutch adjustment is probably just the tech pushing the pedal and saying "yerp that feels fine". Checking the brakes...they probably take a quick glace at them if that. If you can do all the other stuff then DIY. Show your car the love it deserves
Old 01-03-2003, 10:18 AM
Bbasso's Avatar
Couldn't agree more .
stay away from the dealers at all costs.
Old 01-03-2003, 10:21 AM
New User
io_burn's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (Bbasso)
Ehh... You guys are sure if I don't go to Acura that this won't effect warranty claims in the future? I don't want them to be like "Well, you didn't come in for your 37.5k mile service, so your door falling off your car isn't our fault."
Old 01-03-2003, 10:28 AM
Bbasso's Avatar
I see your dilema,,, but having the dealer do shotty work now could cause a problem later...
As for the warranty... There should not be too many things that will go wrong <U>as long as you take care of the car correctly</U>, but ya never know.
If you feel the need to let them check out your car why don't you do the recommended items and then bring it to the dealer, Just be sure to tell them that you have done it but you want them just to ck it out and verify that the car came in for the 37.5 service and to get a receipt saying the car was in fine cond.
If thats a possiblity?
editsp)
[Modified by Bbasso, 2:29 PM 1/3/2003]
Old 01-03-2003, 11:30 AM
JeremyL's Avatar
how do you reset the maint reqd light yourself? mine has been on for the last 40K and its pissing me off
Old 01-03-2003, 11:58 AM
migs's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (JeremyL)
All that work takes under 3 hours to accomplish aside from the fact that you might need to take it in for alignment.
Old 01-03-2003, 12:04 PM
Mugen Mike's Avatar
Look at the underside of the steering column and about half way between the steering wheel and the floorboard there is a button. Hold the button in and turn on the ignition until it goes away.
[Modified by MugenMike, 3:05 PM 1/3/2003]
Old 01-03-2003, 07:11 PM
#417R's Avatar
Default Re: 37.5K mile service... Worth taking to Acura? (1.8L)
Just take to your local Goodyear shop, get them to change the oil and rotate the tires and they can check the brakes for you and if they'll let you walk under the car and look at the exhaust yourself. That's what I do.
jascon
07-18-2004 07:27 AM
TypeR 01 886
01-22-2003 11:54 AM
99ls
08-16-2002 10:53 AM
R0902
08-01-2002 04:17 PM
Black SVT
11-13-2001 03:20 PM
Quick Reply: 37.5K mile service... Worth taking to Acura?
