2001 type r wont start
started up my car let it warm for 10 mins. drove it down the street, starting bogging. then died. tried starting it, it cranks but it wont start and sometimes it wont even crank. no CEL or anything. help anyone?
Dos Pupusas
Re: 2001 type r wont start
Is the car off the street?
If not, get it to your garage asap.
First, you need to check the basics.
Is the air filter clogged?
Do you have fuel pressure?
Does it have spark?
Is there enough compression to start?
After that, check... aaaaaa **** it... just check you battery grounds. It sounds like your starter might be taking a crap. Get the engine to crank over first and we'll go from there. Also, check for a CEL at key on. Does it come on, you hear the fuel pump come on and then goes off?
Does it have spark?
Does it have spark?
Does it have spark?
everything is there, it cranks up fine now. just no sparks. could it be the immobilizer?
cel went out and the green light went out too. i think... i cant remember. i have to put back in my distributor and try it again. try taking the distributor to the the local Acura dealership and they were gonna rip me off by having me take in my car. lol
EDIT: the CEL and the Green light both went out.
Dos Pupusas
Do you have access to a multimeter?
Once you check that, we can condemn your dizzy.
Hear:
Check your dizzy using the colors on the right (OBD2)
Dos Pupusas
Unplug your dizzy.
With someone cranking the engine over, check your positive (+) wires from the diagram above. See what they put out. I think some might be just signals, so you might not see 12V+.
But just to make sure, find the heavy gauge Blk/Ylw wire. That is you ignition coil (+). Measure that with your multimeter. If it shows 12v+ while cranking, then it usually means your ignition coil took a dump. Which you can buy and replace, instead of buying a whole dizzy.
posterchild
06-26-2004 02:09 PM
