"ACG IG" fuse. whats is this fuse for? - Honda-Tech
Old 05-14-2003, 03:48 AM   #1
zRd#1's Avatar
Default "ACG IG" fuse. whats is this fuse for?
Modified by zRd#1 at 1:04 AM 3/1/2005
zRd#1 is offline   Reply With Quote
Old 05-14-2003, 03:54 AM   #2
uNF$@#!'s Avatar
Default Re: "ACG IG" fuse. whats is this fuse for? (zRd#1)
where are these fuses?
sounds like a improper grounding. . and apparently i'm not the best person to ask about fuses.... i thought my headlight fuse was my cigarette lighter fuse
Cetane knows what i'm talkin about
uNF$@#! is offline   Reply With Quote
Old 05-14-2003, 11:40 AM   #3
zRd#1's Avatar
Default Re: "ACG IG" fuse. whats is this fuse for? (Soup ****)
anyone know what these fuses protect?
my fuel pump is not turning on and my car isnt getting any spark.
so... i tested my fuel pump and its good. but i dont know about the dist.
im in desperate need of help. any ideas? thanx.
Old 05-14-2003, 03:08 PM   #4
IG is ignition. Not sure about the ACG though. Check for igntion wires grounding. I had the same problem. The end of an ignition wire had come undone and was hitting a metal plate. Resoldered it and taped it off and havent had a problem since.
Also, where is this fuse? I looked at my car (OBD2) and a friends car (OBD1) and I couldnt find the ACG. Where is this fuse?
VTEC-DA is offline   Reply With Quote
Old 05-14-2003, 03:16 PM   #5
navin's Avatar
Default Re: "ACG IG" fuse. whats is this fuse for? (VTEC-DA)
ACG I belive is under the dash - I once yanked it out and my car wouldnt start, and I freaked out...
navin is offline   Reply With Quote
Old 05-14-2003, 03:31 PM   #6
Eric R's Avatar
ACG is just the type of fuse. In this case it's the "blade" type of fuse. There is the standard blade type and the mini blade type, like in the tegs. Just check for the fuses in the inside fuse box. There's a 10A fuse for the coil/ignition and a 10A for the fuel pump. Check they're ok. not just by its appereance but its continuity with a Ohm meter or test light.
Good luck!
Edit: Sorry! Correction= The fuses on the teg are ATM mini blade type, not ACG.
Standard blade are ATC blade type.
Modified by Tweety R at 3:44 PM 5/14/2003
Eric R is offline   Reply With Quote
Old 05-15-2003, 12:44 AM   #7
zRd#1's Avatar
Default Re: "ACG IG" fuse. whats is this fuse for? (Tweety R)
thanx everyone for ur help.
i ruled out alot of stuff and narrowed it down to the engine harness, then checked everything and found a wire touching ground by the main connector. all fixed now.
THANX again for all ur input.
Old 06-11-2004, 09:58 AM   #8
IntegraB18's Avatar
im having the same problem but i have a 94 vx hatch and my fuse doesnt say ACG (IG) ...mine says ACG (S)....well IG is ignition what can (S) be?...starter?
plz any input will be helpful....thanks
IntegraB18 is offline   Reply With Quote
APEXI N1 EXHAUST zRd#1 For Sale 13 01-04-2005 01:39 PM
1992 Acura Integra LS- SOCAL zRd#1 Vehicles for sale 14 05-26-2004 05:43 PM
1994 Acura Integra LS. all ITR! zRd#1 Vehicles for sale 35 09-29-2003 12:14 AM
ITR wheels! cheap! zRd#1 For Sale 9 01-21-2003 02:54 PM
94 integra (jdm yo!) zRd#1 For Sale 41 12-01-2002 10:34 PM
Tags
94, acg, acgig, acura, box, fude, fuse, fuses, gsr, honda, ig, integra, obd1, s, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
