Old 03-25-2015, 09:08 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Yonaka WS2 Catback Exhaust Review
Old 07-06-2011, 05:46 AM
  #51
ZenkiS14's Avatar
Default Re: Yonaka WS2 Catback Exhaust Review
Can anyone give me a comparison of sound between this and a stock exhaust?
I want something that is as quiet as stock, but looks a lil cooler and will last longer.
Old 07-06-2011, 07:36 AM
  #52
PreyStayShun's Avatar
That's an easy youtube find bud...and stock will last plenty long. If your looking for something that's "cooler" think about getting the ITR axleback.
Old 07-06-2011, 09:30 AM
  #53
dntnedvtec's Avatar
With the Yonaka.
With the 06+ axle back
What about a 06+ Civic Si axle back? I swapped the axle back out for a Civic Si axle back. Sounds pretty mean.
Old 07-06-2011, 09:46 AM
  #54
ZenkiS14's Avatar
I'd love to do something like that, but the main midpipe is what needs replacing the most. So I'd really just want to get a whole new exhaust.
Old 07-06-2011, 11:45 AM
  #55
Why would you do that if you can get 2.5" piping custom done at a muffler shop though? The cost of a whole new exhaust ($500+, for anything decent) doesn't seem to outweigh the function and form of a 2.5" going to a ITR muffler. Saw one on CL the other day for like $100...plus $100 for 2.5" piping at most....
Plus this will stick w/your "quiet as stock, but looks cooler" concept...
Just my $.02 I suppose.
Old 07-07-2011, 05:34 AM
  #56
ZenkiS14's Avatar
I agree, that would be perfect, however it's alot of work for a car I dont really play with at all. This is my daily. And I honestly dont like working on it much, so I just want to be able to bolt something up and just go with it.
So my options are really that Yonaka, OEM, or a used WS2.
Old 07-07-2011, 07:11 PM
  #57
daver's Avatar
i still would like to know if these things last more than a year or two and hold up to salted roads...
Old 07-08-2011, 06:43 AM
  #58
ZenkiS14's Avatar
+1 me too.
Old 07-11-2011, 06:46 AM
  #59
ZenkiS14's Avatar
Well, I just said screw it and bought an Apexi World Sport 2.
Old 07-11-2011, 10:11 AM
  #60
98mugenferio's Avatar
Couldnt you just spray the thing with high temp paint? Or powder coat it if your worried about that? I mean the cost would still come out less than a ws2.
I still need to know if the yonaka or the ws2 for that.matter will clear a rear swaybar on a hatchback
Old 07-11-2011, 11:27 AM
  #61
ZenkiS14's Avatar
yes it does. I bought a used WS2 from a guy that had a rear sway bar on his EH3
Old 03-25-2012, 03:57 PM
  #62
nine7ekhatch's Avatar
Idk if it's just me but I bought this after watching videos and if I take mine past 3grand it has that ricey sound to it nothing like the video of the red teggy
Old 03-25-2012, 04:57 PM
  #63
WhiteNeko's Avatar
Do you have a test pipe or header? I have the yonaka and sounds great without test pipe and header.
I do have one complaint about this system though, the resonator edges would be nice if it was round, I can't get into my garage as it keep getting caught, although I'm not sure if most system has it design like this. My resonator is about an inch and half off the ground. My car has 3" drop.
Here some pics of the clearance I am talking about:
Old 03-25-2012, 05:06 PM
  #64
No Jodas
ShinsenTuner's Avatar
You need to angle or something lol
Old 03-25-2012, 05:12 PM
  #65
Mine is header then exhaust into a resonator then the muffler
Old 03-25-2012, 05:51 PM
  #66
WhiteNeko's Avatar
Wish I can, one car garage and can only open one door just enough to get out. I always park about an inch away from the wall on passenger side sometimes even less, can't even fit my hand between the car and wall. Have to creep my way out on driver side.
Old 03-26-2012, 08:11 AM
  #67
So you don't have a cat on yours either? But I have that problem just with normal driving I was told people see sparks from my car at night ..lol
Old 03-26-2012, 12:12 PM
  #68
Ryan96GSR's Avatar
I was thinking about picking this up when my factory exhaust starts to bite the dust.
I'm curious though, the listings specify that it will only fit the 2000-2001 GSR's, why is that?
I was under the impression the exhaust set up manifold back was the same from on the GSR's from 95-01?
Old 07-02-2012, 10:03 PM
  #69
Ryan96GSR's Avatar
Thought I'd bump this.
I ended up picking this exhaust up about 2 months ago now. I had to lengthen the B-pipe to fit my shorter GSR header/cat. Installation was a breeze. resembles the stock exhausts appearance. My friend's were impressed with it as much as I was. It's quiet enough for my DD which is essentially bone stock aside from this exhaust.
http://www.youtube.com/watch?v=MNqdsT2Vo9U
Old 07-03-2012, 08:43 PM
  #70
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
It may be a civic but has the heart of a gsr. I my exhaust a couple months ago and I am very pleased. I currently have a Hytech style header so there were modifications needed. I plan on added a cat soon. I also decided to cut the tip off. It did caused rasp when I cut it of but I am hoping the cat will cure it.
Old 07-04-2012, 06:21 AM
  #71
Ryan96GSR's Avatar
It should sound better with a cat. Most people I've heard running these exhausts have said the same thing about the raspiness with a test pipe.
Also what do you mean when you say you cut the tip off? If it's the tip after the muffler I can't see that changing much, if at all.
Old 07-04-2012, 06:35 AM
  #72
I posted pics of where I cut the tip off after the muffler. I didn't think it would change anything either but it did so beware. It was the only thing I changed so it was def caused by removing the tip. If you think about it, it does makes since the larger tip would smooth the air flow out before hitting the open air. Almost like the muffler does with the smaller diameter piping going into it. It has a pissed off bumble bee sound between 3400-3500 rpms now when I am hard on the throttle. I plan on adding a new tip but much smaller than the original. I also plan on painting the can black for a more discrete look.
Old 07-04-2012, 11:45 AM
  #73
QuadUp621's Avatar
just got this exhaust in a couple days ago, from the looks of it the quality seems pretty good. will post up some pics when i get the rest of my exhaust in and get it installed.
Old 07-04-2012, 12:02 PM
  #74
Kennyjai's Avatar
Hm very interesting. I always thought tips had a small difference in sound, but not that one can really hear.
I have the 07+ civic si axle back and its quieter than my old vibrant. Sounds pretty unique, not like any other b series honda.
Old 01-27-2013, 07:30 AM
  #75
xTyFighterx's Avatar
Bought mine a few months ago have gone through winter with it an still looks new I'm running a power chamber intake stock header and cat and its the best sounding exhaust I have ever owned I get a subby rumble at certain rpms don't know why ha but couldn't be happier
And I'm in north Idaho lots of snow and salt
Quick Reply: Yonaka WS2 Catback Exhaust Review
