Which wire does the tach hook up too? - Honda-Tech
Old 01-12-2005, 08:12 PM   #1
Dropped90Integra's Avatar
Default Which wire does the tach hook up too?
I just bought a Autometer Phantom Tach and need to know which wire on the connector of my 90 GS Teg does that wire from the tach hook to on that connector... need to know soon.... thanks for the help
Dropped90Integra is offline   Reply With Quote
Old 01-12-2005, 08:45 PM   #2
LSRracing95's Avatar
Default Re: Which wire does the tach hook up too? (SlammedDAHatch)
i have a ractive tach, i believe i piggybacked it to either a blue or green wire in the distributor..
LSRracing95 is offline   Reply With Quote
Old 01-12-2005, 08:47 PM   #3
Default Re: Which wire does the tach hook up too? (LSRracing95)
Yea, I think there a blue, green, and than a lot of white with blue or green lines on them..... just don't know which is which
Old 01-12-2005, 09:11 PM   #4
Racermech's Avatar
Ok it has been a long time since i put a tach in my old DA, but i swear we hooked it to the green in the distributor, double check, but i am pretty sure that is correct
Racermech is offline   Reply With Quote
Old 01-13-2005, 09:57 PM   #5
Default Re: Which wire does the tach hook up too? (Racermech)
ya, im pretty sure its the green wire on the distributor as well.. if not, try the blue.. one of em will work
Need speedo and tach in dirt track car Civic Racer X 7 Honda Civic / Del Sol (1992 - 2000) 3 07-24-2014 07:34 AM
Obd1 harness obd2b dizzy.. Where to get tach signal uvamosk Engine Management and Tuning 3 07-07-2011 01:08 AM
rpm signal wire ekhatchey Honda Civic / Del Sol (1992 - 2000) 8 09-10-2009 07:59 PM
Autometer Tach Wiring Help! (Already Searched) 4gen4drcivic Honda CRX / EF Civic (1988 - 1991) 10 02-02-2009 10:23 AM
Anyone have a faze Tach? standbackimapro Honda Civic / Del Sol (1992 - 2000) 2 09-05-2007 01:27 PM
Tags
1992, 2000, 92, autometer, civic, connection, green, honda, hook, hookup, integra, model, motorcycle, tach, tachometer, wire, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
