Where is the fan relay on a 90-93 integra
Old 12-07-2005, 02:14 PM
jdmcivicferio's Avatar
Default Where is the fan relay on a 90-93 integra
Its cold and my fan is stuck running all the time, I'm pretty sure its the fan relay, where abouts is it located on a 90-93 integra thanks
Old 12-07-2005, 02:55 PM
Echo7847's Avatar
Default Re: Where is the fan relay on a 90-93 integra (jdmcivicferio)
Should be in under hood fuse box, make sure your fan switch isnt stuck closed.
Old 12-07-2005, 04:22 PM
Polintan's Avatar
There is no relay on the teg for fan.. Its the blower resistor might be the fault or some messed up wiring giving constant power to the blower motor.
Get a manual helps alot.
Good luck
Old 12-07-2005, 06:21 PM
SwedBoy2999's Avatar
Ldo
12-08-2008 11:43 AM
Jonathan_ED3
09-27-2008 10:11 AM
Run Away
06-07-2008 10:12 AM
og asr
07-04-2005 12:33 AM
Archidictus
02-11-2004 10:57 AM
Quick Reply: Where is the fan relay on a 90-93 integra
