Where is the A/C Compressor Clutch Relay located???
Old 08-20-2005, 03:15 PM
95TEG's Avatar
Default Where is the A/C Compressor Clutch Relay located???
Can someone tell me where the A/C compressor clutch relay is located on a 95 Integra LS? I cant find the damn thing. Thanks.
Old 08-20-2005, 06:36 PM
Banned
RaceCity_USA's Avatar
Default Re: Where is the A/C Compressor Clutch Relay located??? (95TEG)
Well, Rob, I have a 94 GSR, and on it, the compressor clutch relay is located in front of the A/C condensor, behind the front bumper cover. (No wonder you can't find it!) If you reach up through the lower bumper cover opening, behind the bumper brace, you'll find it right behind the 'e' in the "Integra" imprint on the bumper. There are actually 2 relays located together there. The A/C compressor relay is the one on the drivers side (on the right facing the rear of the car).
Hope this helps,
Dave
Old 08-21-2005, 05:35 PM
95TEG's Avatar
Default Re: Where is the A/C Compressor Clutch Relay located??? (RaceCity_USA)
Hey thanks Dave. So the one on the right is for the compressor clutch or the compressor? Just want to make sure I get the right one. Thanks again.
Rob
Old 08-21-2005, 06:37 PM
Banned
The A/C compressor relay is the one on the drivers side of the car. When you are reaching up under the front bumper and feel the two relays, it will be the one on your right.
Dave
Old 04-24-2016, 04:07 PM
Scott Forbes's Avatar
96project
07-30-2011 04:39 PM
hondaZvic
09-22-2009 06:04 PM
DB1_559
05-18-2009 08:55 PM
turbob16ef
01-11-2006 03:47 PM
Quick Reply: Where is the A/C Compressor Clutch Relay located???
