Wheel bearing problems
Old 03-19-2009, 12:49 PM
thunderboy's Avatar
Default Wheel bearing problems
How to know when you have a bad wheel bearing? And how to change front wheel bearing?
Old 03-19-2009, 04:55 PM
TegraD's Avatar
Default Re: Wheel bearing problems
jack up the tires, grab them and see if you can rock them in and out of the tire well( life towards the engine and back to you) if it moves, the bearings are bad...
replacing them sucks... the are pressed in so you have to take off the spindle set and take it to a shop or if you know anyone who has a 2 ton + press you will be set.
you push out the hub, then the bearing and then the reverso order to put it back in...
all in all, its not to bad. just becareful pushing the new bearing in, you can easily mess them up. good luck.
Old 03-19-2009, 05:04 PM
AW
AW's Avatar
https://honda-tech.com/forums/acura-integra-6/wheel-bearing-replacement-using-hub-tamer-no-press-needed-1996133/
Go to this thread that I made on replacing wheel bearings. I am doing the other side this weekend as it is so loose now you can move the wheel alot.
Old 03-19-2009, 05:44 PM
shawndb1's Avatar
Mine is due and it hums like crazy. If you can't push out the bearings with a press, you can simply change the hub and most kits come with a new bearing. More expensive yes, but less work and you can easily do it.
Old 03-19-2009, 09:31 PM
SuckMyDOHC's Avatar
Theres a new tool that makes it real easy and can be done in about 20-30 minutes. I forgot who makes it, but check the typical tool trucks.
Old 03-20-2009, 01:43 AM
AW
AW's Avatar
If you look at my link, the original tool to do this job is shown. I used the hub tamer to remove the bearing.
Old 03-20-2009, 06:59 AM
twentyhurtz's Avatar
when mine went out on my left spindle there was no warning, just went around a curve one day and heard the most god awful grinding noise, driving straight you could not hear it just around curves, when i jacked up my car you could move the wheel ALOT, i was told by someone that its the worst one they ever seen, ha. now i got to do my right side, it moves a little. i just went to auto zone, bought new bearing and lower ball joint - looked rough, and went to a machine shop, they charged me 60 to press in both, all in all spent about 125 for new ball joint and wheel bearing pressed in.
Old 03-20-2009, 08:44 AM
Reject Papi
jhammond_82's Avatar
i know, and am sure lots of people know the sound they make, but i'm not sure how to type it. lol.
Old 03-20-2009, 12:15 PM
teg_dc2's Avatar
humming sound is what i got, i think i might have to change my bearings also, is there front and rear bearing i change all at once or only two at a time??
SomeDude56
10-30-2006 10:49 AM
petergriffen
08-11-2006 08:44 PM
FakeJDMEF8
18
11-22-2005 08:13 PM
ViZ
02-11-2005 07:52 PM
nwdrifter
09-28-2004 12:15 PM
Quick Reply: Wheel bearing problems
