Whats the best way to remove the shifter linkage spring pin(split pin)?????????
Old 03-14-2007, 09:02 PM
Boosted_JDM's Avatar
Default Whats the best way to remove the shifter linkage spring pin(split pin)?????????
Trying to remove my engine and am in the process of removing the shifter linkage from the transmission. I am trying to remove the spring pin with a punch and hammer. Hitting it doesnt seem to move it, and am worried if I hit it too hard it will damage the tranny. What should I do?
Would heating it, with a small propane torch help?
Is the enter and exit point for the pin one way or it doesnt matter?
Also, is drilling it out a posibillity?
Old 03-14-2007, 09:25 PM
thewrai6th's Avatar
Default Re: Whats the best way to remove the shifter linkage spring pin(split pin)????????? (Boosted_JDM)
The punch should not be tapered, and a little smaller than the pin. Hammer that sucker out. I think it's easiest to use the side of the hammer when you are under the car laying on your back.
Old 03-15-2007, 02:19 AM
{Mineral Grey} ITR's Avatar
Default Re: Whats the best way to remove the shifter linkage spring pin(split pin)????????? (thewrai6th)
An old trick is to use the catalytic converter bolts(the one with the springs). It is a straight shot in with a hammer.
Old 03-15-2007, 08:44 AM
Sam92Teg's Avatar
Disconnect the linkage at the shifter and pull the engine with the linkage still attached to the tranny. Then if you still need to remove it, do so once the engine is pulled, much easier.
Old 03-15-2007, 10:11 AM
LoseRPunKx182's Avatar
Default Re: Whats the best way to remove the shifter linkage spring pin(split pin)????????? (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Disconnect the linkage at the shifter and pull the engine with the linkage still attached to the tranny. Then if you still need to remove it, do so once the engine is pulled, much easier.</TD></TR></TABLE>
thats what i do
Old 03-15-2007, 02:07 PM
thewrai6th's Avatar
Default Re: Whats the best way to remove the shifter linkage spring pin(split pin)????????? (LoseRPunKx182)
+1 ^ , this is how I got my first one out.
ryc555
07-14-2007 10:46 PM
chu77
08-28-2006 01:30 PM
arrojj
02-15-2006 02:10 PM
mykem
19
08-15-2004 02:00 PM
Random.Hero
02-03-2002 10:14 AM
Quick Reply: Whats the best way to remove the shifter linkage spring pin(split pin)?????????
