Whats this
Old 02-03-2012, 12:27 AM
MurtazaDSM's Avatar
Default Whats this
I was takink the head on my gsr and broke the red piece. Can someone tell me what it is and do I need a new one or is it not needed
also what condition is my pistons in they all look alright except cylinder 4 is it lean?
Old 02-03-2012, 12:37 AM
EK9
Dc4LsTeG's Avatar
Default Re: Whats this
Pcv don't need it you can block it off there and cap where it connects to the intake manifold. And somethings not right for one piston looking way different. More info on your set up? Stock gsr with stock gsr ecu?
Old 02-03-2012, 03:37 AM
Solster's Avatar
Umm you DO need the PCV as this is how the crank case is vented it also help keep seals from blowing out from blow by.
besides there cheap like around $5
lazlong's Avatar
Check the injector on #4 for proper operation. If it has an EGR the EGR may need cleaning.
Old 02-03-2012, 03:40 AM
Solster's Avatar
as for your pistons looks like 1~3 were getting too mush fuel or oil and 4 looks like it was running lean if at all.
Old 02-03-2012, 05:11 AM
kyden's Avatar
if #4 was running, i suspect it had a leaky headgasket in that location.
Old 02-03-2012, 09:11 AM
EK9
Dc4LsTeG's Avatar
Umm No you don't NEED it mine was blocked off forever until I want turbo and needed a catch can.
Old 02-03-2012, 10:17 AM
kyden's Avatar
please don't go around telling people this.
Old 02-03-2012, 10:21 AM
EK9
Dc4LsTeG's Avatar
Telling them what? You don't NEED it, works perfectly fine blocked off. It is better to have it though. But his question was does he NEED it
Old 02-03-2012, 10:30 AM
nonvtecD's Avatar
Cylinders 1-3 look fairly normal operation, depending on the miles. Cylinder 4 looks steam cleaned, as in HG leak.
Old 02-04-2012, 12:33 AM
mouab18c1's Avatar
LOL Honda made it for a reason. Either keep the stock ventilation or upgrade.
Old 02-04-2012, 08:51 AM
el crapitan's Avatar
the pcv system helps by relieving pressure and pulling moisture from the crank case.
water and oil don't mix too nicely. it's pretty important. just because you can remove one component from the engine and not have IMMEDIATE effects, doesn't mean it's alright to do.
besides, it's super easy to fix while the head's off. farting around back there from underneath the vehicle would be a pain. or you'd have to remove the intake manifold for access later on. unless, as stated, he wants to install a catch can
Old 02-05-2012, 01:57 PM
MurtazaDSM's Avatar
alright cool thanks guys and I had a feeling it was the pcv valve because when I took the head off the block heard something break and saw that broken piece and yes I am going to replace it and yea I thought that 1-3 was normal for 165xxx miles and my head gasket did blow along with all my exhaust valves lol
Old 02-05-2012, 02:56 PM
Whiterice-gsr's Avatar
i dont have a pcv or a catch can lol.
dc2_530
02-08-2013 07:24 AM
ja20_eg
12-15-2011 05:25 PM
AiL45
11-25-2006 04:57 AM
SleepingCivic35
03-10-2006 01:19 PM
TurboSC
07-23-2005 08:44 AM
Quick Reply: Whats this
