What are the symptoms of bent valves? - Honda-Tech
Old 12-11-2010, 01:59 PM   #1
vtec@4000rpm's Avatar
Default What are the symptoms of bent valves?
i got a 90 DA9 ls with a b16a i may have bended valves but im not sure. if i do the guy before me couldnt put it on gear. so i wanna know wat does a car with bended valves do
vtec@4000rpm is offline   Reply With Quote
Old 12-11-2010, 02:13 PM   #2
H-T Order of Merit
Default Re: What are the symptoms of bent valves?
When you say he couldn't put it in gear, what do you mean? He couldn't move the gearshift from neutral to any of the gears? That sounds like a transmission/clutch problem, not an engine problem like bent valves.
I'm not a technical expert but I had an engine that jumped the timing, and the engine wouldn't run. You could crank it and it would start but it would run VERY rough and you had to keep your foot on the gas to keep the revs way up; the instant you let off the gas or tried to let out the clutch, it would die.
nsxtasy is offline   Reply With Quote
Old 12-11-2010, 02:36 PM   #3
bent valves/ skipped timing will cause a loss in compression.
it has nothing to do with the transmission
el crapitan is offline   Reply With Quote
Old 12-11-2010, 07:36 PM   #4
fv8s's Avatar
Quote:
Bent** valves. And what do you mean "couldn't put it on gear"?
fv8s is offline   Reply With Quote
Old 12-11-2010, 09:14 PM   #5
wunfstgsr's Avatar
ow you will know when you have bent valves, when the car sounds like a suburu then you know.
wunfstgsr is offline   Reply With Quote
Old 12-11-2010, 09:29 PM   #6
EHondaJDM's Avatar
Quote:
Originally Posted by EHondaJDM View Post
OLD SCHOOL TRICK TO CHECK FOR BENT VALVES:
-Get a uncreased piece of white lined paper (Not construction paper or similar its too thick)
-Let your car warm up to operating temp and allow it to idle
-Hold the paper flat over your exhaust so it covers the end completely
-Watch the paper closely, if all is normal it should just keep flapping outward. If you have a bent valve the paper will get sucked into the exhaust before it is pushed out
Only other way I've seen it done without taking the head off is using a fiber cam
EHondaJDM is offline   Reply With Quote
Old 12-15-2010, 05:21 PM   #7
verycooljdm's Avatar
They have bent valves on purpose too no?
verycooljdm is offline   Reply With Quote
Old 12-16-2010, 05:34 AM   #8
vrrodri's Avatar
Had the same thing happened to me recently, it jumped timing after an install, not sure how the hell that happened but it ran very rough and required gas to keep it from dying. Luckily it did not bend any valves.
vrrodri is offline   Reply With Quote
Old 12-16-2010, 06:41 AM   #9
EHondaJDM's Avatar
Quote:
What are you talking about??
Old 12-16-2010, 08:40 AM   #10
Dynasty21's Avatar
Location: Where We Squeeze 1st N Ask Questions Last, CA, USA
I believe he was referrin to Subi's have bent valves.
Dynasty21 is offline   Reply With Quote
Old 12-16-2010, 08:59 AM   #11
EHondaJDM's Avatar
Quote:
Oh, this guy had me nervous for a min
Old 01-10-2012, 08:42 AM   #12
No hes right if you have a bent valves its gana SOUND like a sti subaru
toby350 is offline   Reply With Quote
Old 01-10-2012, 08:44 AM   #13
it'll sound like a subaru if its even running, i know on my evo when the shop messed up my car and my valves bent, car wouldnt run
bryan24207 is offline   Reply With Quote
Old 01-10-2012, 09:17 AM   #14
The Grumpiest
grumblemarc's Avatar
Thread resurrection!
grumblemarc is offline   Reply With Quote
Old 01-10-2012, 09:19 AM   #15
haha i just noticed the dates on it, guess toby had alot of spare time to do some reading
Old 01-10-2012, 11:02 AM   #16
why an sti? Why cant it be like a wrx or a legacy or a forester, or an RS?
Hidenplanvew is offline   Reply With Quote
Old 01-10-2012, 04:53 PM   #17
i think subaru sound great.
vedocustoms128 is offline   Reply With Quote
Old 01-10-2012, 05:53 PM   #18
RookieCivic's Avatar
Quote:
YES! but when your honda sounds like one you might have some problems
RookieCivic is offline   Reply With Quote
Old 01-10-2012, 11:13 PM   #19
01oemTeggy's Avatar
Quote:
x2 My integra sounded like a subaru when i had a bent valve. It was cool having all my friends like. "whoa, did you rebuild your teggy with performance parts?" Then i felt stupid and gave them the answer.
01oemTeggy is offline   Reply With Quote
Old 01-10-2012, 11:28 PM   #20
DirtyDA9's Avatar
Ahhh I totally forgot about this trick, oldschool stuff right here, one of the first "tricks of the trade" I learned.
DirtyDA9 is offline   Reply With Quote
Old 01-10-2012, 11:30 PM   #21
DirtyDA9's Avatar
Quote:
Or an unequal lenght header. I've totally been thinking about having one fabbed up, I love the sound of subbies, and everyone will look like "wtf?" thinking it's messed up or ej205 swapped lol
Old 01-10-2012, 11:31 PM   #22
DirtyDA9's Avatar
Quote:
Why not just subaru lol
Old 01-13-2012, 10:11 AM   #23
Had a bad valve, it was running on 3 cylinders, sounded like a subaru and felt a great loss in power, mostly at low speed and getting off the line
seth01tuner is offline   Reply With Quote
Old 02-13-2012, 09:27 AM   #24
chrisdavis6's Avatar
exactly what my gsr sounded like when i busted the belt.
Replaced it, started it up, sounded like an sti!
rebuilding head now, what a bitch getting old valve guides out!
chrisdavis6 is offline   Reply With Quote
Replacing valves Boyle.R Forced Induction 3 06-12-2013 04:19 AM
bend valves ??? pic request DB1_559 All Motor / Naturally Aspirated 1 12-19-2006 01:37 AM
how can i check my valves to see if they are bend and also check the valve seal? Sinner Tech / Misc 4 12-13-2005 02:30 PM
96' accord LX Interference engine ? 89dxhunchback Honda Accord (1990 - 2002) 6 12-28-2003 12:44 PM
Getting the head back tommorrow from bending valves... CW-ITR-329 Acura Integra Type-R 2 06-10-2002 09:23 PM
Tags
97, accord, b18, bent, check, civic, honda, integra, signs, symptoms, symtoms, tech, valve, valves, vavles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
