Need timing help fast
Old 02-12-2012, 03:19 PM
brad22486's Avatar
Default Need timing help fast
Changing timing belt b18b need to know how to set timing please help fast thanks
Old 02-12-2012, 03:26 PM
EK9
Dc4LsTeG's Avatar
Default Re: Need timing help fast
Have you searched? You don't have a Haynes manual?
Old 02-12-2012, 03:44 PM
brad22486's Avatar
Yea have searched and no haynes
Old 02-12-2012, 04:01 PM
TheRealTegger's Avatar
You must have the belt off already...
Engine MUST be at TDC #1 cyl compression.
Crank pulley mark lined up with mark on oil-pump.
Cam pulleys with "UP" marks facing up. There are marks on the cam pulleys that will now point towards each other. Get them perfectly in alignment.
Put drill bits into the holes in the fronts of the camshafts.
Now try and get the belt on with the cam pulley marks still perfect. It is NOT easy to do without ending up with one cam off by a tooth.
If the old belt is still on, use Wite-Out to make marks on the pulleys and crank, and on the belt where it meets those items. Slide old belt off. Transfer marks to new belt and install. Piece of cake.
Old 02-13-2012, 05:32 AM
brad22486's Avatar
K thanks
gravity73
02-09-2014 03:05 PM
giovannie23
08-09-2013 08:30 PM
7andaswitchblade
06-01-2007 01:46 PM
Seedc2
03-22-2005 04:53 PM
SHG_EasyE
03-09-2005 10:10 AM
Quick Reply: Need timing help fast
