...What psi should my tires be at??
Old 02-04-2005, 12:46 PM
escape2me's Avatar
Default ...What psi should my tires be at??
I have a some yokohama v-rated yk420 tires on my teg... what psi should they be at for daily driving?
Old 02-04-2005, 12:56 PM
RDSDC2's Avatar
Default Re: ...What psi should my tires be at?? (97 GSR)
look at the sidewall...if it is just you then you can go a couple psi lower, if you have passengers riding alot, then go a couple higher.
Old 02-04-2005, 01:02 PM
timmy8151's Avatar
Default Re: ...What psi should my tires be at?? (ReddragonDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddragonDC2 &raquo;</TD></TR><TR><TD CLASS="quote">look at the sidewall...if it is just you then you can go a couple psi lower, if you have passengers riding alot, then go a couple higher.</TD></TR></TABLE>
IIRC, the sidewall has the max psi the tire can handle. I usually go no higher than 10 psi less than the max pressure. I have my tires set anywhere from 33-35 psi.
Old 02-04-2005, 01:10 PM
escape2me's Avatar
Default Re: ...What psi should my tires be at?? (timmy8151)
thanks guys
Old 02-04-2005, 03:05 PM
escape2me's Avatar
i measured it and it said 24 psi... and the tire isnt low at all, that cant be right
Old 02-04-2005, 03:11 PM
B18OnTop's Avatar
I do 36 front and 34 back. Just pump them up somemore.
Old 02-04-2005, 03:12 PM
GreenGSR's Avatar
what size are the YK's?
Old 02-04-2005, 03:29 PM
The-LS's Avatar
check the door jam NOT the tire... the tire won't tell you anything.
Old 02-04-2005, 03:34 PM
Darth ModerVader
Padawan's Avatar
Default Re: ...What psi should my tires be at?? (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">check the door jam NOT the tire... the tire won't tell you anything. </TD></TR></TABLE>
Exactly.
Old 02-04-2005, 03:41 PM
Irish Integra's Avatar
That sticker is really only for standard wheel/tyre setups. although it's a good guide. Put in about 30-34 for 15", 32-36 for 16"and about the same for 17". 34 is usually a pretty good round figure, IMO
..::91TEG-G2::..
11-24-2007 07:45 AM
.water
01-28-2005 02:32 PM
HondaGus
05-21-2004 11:54 PM
rayweipu
12-06-2002 08:13 PM
vpforeva
10-13-2001 08:57 AM
Quick Reply: ...What psi should my tires be at??
