What Kind of Brake Fluid Are You Using
Old 07-16-2011, 04:19 PM
PreyStayShun's Avatar
Default What Kind of Brake Fluid Are You Using
Getting ready to re-do my brakes, including stainless lines etc...
As mentioned...what kind of brake fluid are you all using? Any good suggestions?
Old 07-16-2011, 04:27 PM
Drive 4 fun's Avatar
Default Re: What Kind of Brake Fluid Are You Using
ATE blue and alternate Gold to easy fluid change. Readily available off the shelf and good temp rating dry and wet. There are charts on HT with temp ratings and ATE is good, not the best. I have not had it fail or boil.
Old 07-17-2011, 05:09 AM
rico05's Avatar
Motul RBF600.
Old 07-17-2011, 06:24 AM
Billy13's Avatar
depends on what you are doing with the car, you dont need high temp stuff unless you run track days.
street driving and autox all you need is valvoline synthetic
tracking the car i use pentosin racing fluid.
Old 07-17-2011, 07:03 AM
Spawne32's Avatar
valvoline synthetic dot3/4
Old 07-18-2011, 04:13 AM
Daisy... Daisy...
Dogginator's Avatar
I use Motul RBF600.
Its cost and properties guided this decision.
This is from an old version on StopTech's site.
Arranged by DRY boiling point:
DRY: 401F -- WET: 284F --- DOT3
DRY: 446F -- WET: 311F --- DOT4
DRY: 502F -- WET: 343F --- Valvoline SynPower
DRY: 509F -- WET: 365F --- Motul 5.1
DRY: 527F -- WET: 302F --- AP Racing 551
DRY: 536F -- WET: 392F --- ATE Superblue/TYP200
DRY: 590F -- WET: 410F --- AP Racing 600
DRY: 590F -- WET: 518F --- Castrol SRF
DRY: 593F -- WET: 420F --- Motul RBF600
DRY: 610F -- WET: 421F --- Neo-Synthetic Super DOT 610
Arranged by WET boiling point:
The SRF was the best, but it was absurdly expensive.
Old 07-18-2011, 04:38 AM
90efb16's Avatar
Honda genuine brake fluid dot 3
Old 07-18-2011, 08:31 AM
"I use Motul RBF600."
What is the cost and can you walk into a vendor and pick it up, or order ahead?
Old 07-18-2011, 08:39 AM
Daisy... Daisy...
Dogginator's Avatar
It's about $15/500ml online. A local speed shop may carry it.
Old 07-18-2011, 08:55 AM
Fortunately, I have not overheated ATE. Bang for buck, ATE is about $12-13/L, enough for a flush. I can find it in a few places locally, mostly blue and usually ATE 200. I thought the price break is at ATE in the chart above. Wet point gets decent at ATE also.
Old 07-18-2011, 12:35 PM
s2r
s2r's Avatar
I use ATE blue on my car and not had any problems driving on street, canyons, track. The nice thing with the ATE Blue is you can see clearly when you are done flushing it, and it pretty inexepensive. It is also available in a yellowish color for the future change overs. My friend uses it in a race m3 and never had a problem either.
Old 07-18-2011, 12:44 PM
MoreCowbell's Avatar
Pensoil synthetic
Old 07-18-2011, 01:00 PM
1998GsRIntegra's Avatar
ATE Super Blue or AP Racing, just my preferences.
Old 07-18-2011, 06:42 PM
Another note on Valvoline Synpower. The information in the chart is the old, original, formula. A few years ago they changed the look of the bottle and the formula. Dry boiling is 480F and wet 330F, off of the bottle, in my hand. I contacted them to confirm this, again a few years ago, and they had reformulated and confirmed 480 dry and 330 wet. I switched to ATE.
Old 07-19-2011, 02:11 AM
Robinjo's Avatar
This is what I run as well for Autocross. Change it every off-season because it doesn't work as well when it absorbs moisture. The two tones make it easy to tell when you have all the old fluid out.
For my daily driver I just whatever crap is on sale at the parts store...
Those running Motul, are you flushing every year as well?
Old 07-19-2011, 04:37 AM
Daisy... Daisy...
Dogginator's Avatar
I flush every year with Motul.
The chart data that I posted shows that the Motul RBF600, ATE, and AP Racing 600 are all competent fluids for competition use. For daily use, run a DOT 3 or 4 fluid.
Dot 3 and 4 fluids are completely miscible and compatable with your system. Do not run a DOT 5.
Old 07-19-2011, 08:48 AM
TOO MUCH TORQUE's Avatar
prestone from walmart
Old 07-19-2011, 02:50 PM
sc34dc4's Avatar
ATE typ 200 "gold" I order from north american motorsports. It's $12 and shipping is cheap.
Old 07-19-2011, 03:19 PM
Global Moderator
Jimmy's Avatar
JDM ITR 36mm 5 lug conversion, Spoon Calipers, Hawk HP+ pads in the front, OEM Honda Type R pads in the rear. Stainless steel lines front/rear with ATE Blue fluid.. just had it out on the track all day Sunday.. no issues
Check out ImportDPS for good deals and all the sponsors in the marketplace usually have the cheapest prices
https://honda-tech.com/forums/members/importdps-999596440/
Old 07-19-2011, 03:27 PM
Moderator
TheShodan's Avatar
Motul makes a Dot 5.1 for street use I've been runnning for about 3 years on my wife's wilwood civic SI
Old 07-20-2011, 06:30 AM
Daisy... Daisy...
Dogginator's Avatar
DOT5.1 is not the same as DOT5 (silicone based). DOT5 is hydrophobic, so water will phase seperate in the lines and can cause vapor issues. I personally do not like the DOT5.1 designation, as it will lead to someone thinking that DOT5 is OK to use.
http://en.wikipedia.org/wiki/DOT_5.1
Old 07-20-2011, 04:30 PM
SleepyPanda's Avatar
i personally use Motul RBF600 or ATE super blue. but IMO if its your daily dot3 will be just fine.
Old 07-20-2011, 04:33 PM
battmancjz's Avatar
Valveline synthetic
Old 07-20-2011, 04:48 PM
HT Black OPs
00IntegrAllmotoR's Avatar
Motul DOT5.1- Daily
Motul RBF600- Track Use
Nice Fit
Honda Fit
03-05-2009 06:23 PM
slow91crx
12
05-17-2005 05:38 PM
kommon_sense
01-04-2005 11:46 AM
CivicSiRacer
24
05-15-2003 12:03 PM
jdm92accord
01-30-2002 09:29 AM
Quick Reply: What Kind of Brake Fluid Are You Using
