what the hells wrong with my car now
* B A N N E D *
okay so now my car, i installed the turbo timer.. it was fine after that, now when i'm at high rpm, the brake light flickers and ****, the car is getting a shakey most of the time, and when i pull the ebrake up. the brake light doesn't come on....also when i go to shift my rpm's down fall down as much as i think they should, and my clutch feels kinda weak for a stage 3...
i don't know any other way to put it..
but hopefully someone can take what i said and help me out.
Re: what the hells wrong with my car now (iHOPEyouCHOKE)
Your brake light doesn't come on when you pull up the brake? Have you checked the ground?
Did you install the Turbo Timer yourself? Most of them that I have installed, you need to tap into the ebrake wire -and maybe check were they or you tapped that wire out, sounds like it was simply disconnected.
montrealracing
Honda Civic (2001 - 2005)
04-09-2008 07:53 AM
shadow_ridge
08-11-2005 10:35 PM
