What could cause a distributor to go bad? - Honda-Tech
Old 07-26-2006, 06:35 AM   #1
Danziver's Avatar
Default What could cause a distributor to go bad?
I have bought 2 new distributors and so far each one has only last me about 2 months. Im on my 3rd one and its starting to act up too. It is starting to give me hard starts and it killed on me this morning. Anyone have this problem?
Thanks
Danziver is offline   Reply With Quote
Old 07-26-2006, 06:46 AM   #2
motoman's Avatar
Default Re: What could cause a distributor to go bad? (Danziver)
I have had distributors die from having bad grounds.
motoman is offline   Reply With Quote
Old 07-26-2006, 06:46 AM   #3
Danziver's Avatar
Default Re: What could cause a distributor to go bad? (motoman)
Where are the grounds you speak of?
Old 07-26-2006, 07:01 AM   #4
crx_88_si's Avatar
thermostat ground.
are these 100% new, or used? did u reuse the coil? ignitor? cap ?
crx_88_si is offline   Reply With Quote
Old 07-26-2006, 07:07 AM   #5
Danziver's Avatar
Default Re: What could cause a distributor to go bad? (crx_88_si)
Its re-built from advance auto parts and its my 2nd one from them. Cap, rotor, ect are all new.
Im gonna check my grounds, any more info would be appreciated.
Old 07-26-2006, 07:13 AM   #6
Danziver's Avatar
Called my local mechanic and he said he couldnt see any reason for them to just die like that, other than the fact that its a cheap rebuild. Im gonna try to replace my grounds today. Anyone have any experience with this weird problem?
Old 07-26-2006, 11:37 AM   #7
Danziver's Avatar
Just added some new ground wires. Anymore ideas?
Old 08-17-2006, 06:06 PM   #8
Danziver's Avatar
Up
Old 08-17-2006, 06:35 PM   #9
erikiksaz1's Avatar
Maybe try distributorking? I've used two for a period of about six months and so far, so good. Let's hope
erikiksaz1 is offline   Reply With Quote
Old 08-17-2006, 06:46 PM   #10
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: What could cause a distributor to go bad? (erikiksaz1)
is there oil pooling in the spark plug sockets?
wrx-killer-Sti-eater is offline   Reply With Quote
Old 08-18-2006, 01:18 AM   #11
tyco's Avatar
Had the same problem before, check spark plugs if oil is pooling in, also check to see if the bolts are tight on the distributor, it happen to me and started acting up
tyco is offline   Reply With Quote
Old 03-22-2011, 10:46 AM   #12
koreachangsu's Avatar
Quote:
Hey I know this I. An old thread. Oil is in my spark plug sockets. I have no spark I went through 2 dizzy's.my question about this thread is what if oil is on the plugs or in the cylinder of the wire plug. Won't your car just start but sound shitty.
koreachangsu is offline   Reply With Quote
Old 03-22-2011, 12:28 PM   #13
Quote:
i cant speak for anyone else but when i bought my 90 DA it needed plug gaskets and always had oil soaking the the plugs and wires. which in turn ruined the wires and caused them to slip of the plug and kill the car or would have a loose connection and would starve the electrical power to make it bog but it hasn't seemed to hurt my distributor. so that may be a slight part of your problem but i dont see how it would kill your dizzy. have you checked all of your wires that run to the dizzy plug to make sure that none of them are shorting out?
djkobe is offline   Reply With Quote
h22a into 94 EG, no spark... 2 distributors, internal.. external.. which one? blackbndt Honda Prelude 1 07-31-2010 05:27 PM
H22A7 in DC2, what kind of distributor? higany4819 Hybrid / Engine Swaps 5 06-20-2008 01:56 PM
new distributor no spark though IlsCrx Honda CRX / EF Civic (1988 - 1991) 1 03-29-2006 12:17 AM
91 integra b16a starting problems lu2hot Tech / Misc 1 07-30-2004 06:45 PM
Could this problem be the distributor? JDMBB2 Honda Prelude 3 01-25-2004 10:17 AM
Tags
bad, car, cause, distibutor, distributor, distributors, honda, hondas, integra, makes, months, plugs, problems, reason, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
