what should i do now?
Old 04-21-2007, 03:37 PM
DeCoY's Avatar
Default what should i do now?
INFO: JDM B18C Integra GSR motor/Hydro tranny
So i went to change my tranny fluid today not knowing how long since the last change. I jacked up the car in the front, Unbloted the top 17mm bolt and probably about 8 oz. of clear, clean tranny fluid came out. so i popped the bolt back in and now im worried... did that much come out because it was probably filled on a lift? and is that much less going to be dangerous to drive on?
should i take it to a shop where it can be filled on a lift, or should i be ok?
Any advice much appreciated.
Old 04-21-2007, 06:59 PM
* B A N N E D *
Jtuned DC2's Avatar
I think it was over filled. Um look for more answers. BUMP
Old 04-21-2007, 11:44 PM
98GSRDC2's Avatar
Default Re: what should i do now? (DeCoY)
just put your car on 4 stands. you can do it all by yourself. just bleed
Old 04-21-2007, 11:48 PM
davidluko's Avatar
^Why do you need to put the car on jackstands, and what do you need to bleed? You can reach the bolts with the car on flat ground with the wheel on and there's nothing to bleed.
wessieball
02-20-2009 03:29 PM
spintboy
01-20-2008 09:24 PM
.one lane
05-02-2006 05:38 AM
TrueUntilDeath.com
08-09-2004 08:26 AM
People_Mover
07-25-2003 05:18 AM
Quick Reply: what should i do now?
