valve cover gasket
Re: valve cover gasket (sleepyIntegra)
Well, remove the spark plug cover if you have it, remove spark plug wires, then proceed to loosen the nuts on the cover in a cross-hatch fashion so you don't cause anything to warp, then once all nuts are off pull up.
Re: valve cover gasket (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Well, remove the spark plug cover if you have it, remove spark plug wires, then proceed to loosen the nuts on the cover in a cross-hatch fashion so you don't cause anything to warp, then once all nuts are off pull up.</TD></TR></TABLE>
don't forget to put gasket sealant on the corners of the rounded parts of the gasket.
PunkRudeBoy
12
05-05-2018 09:04 PM
themorphious
06-03-2006 12:14 PM
standbackimapro
12-16-2005 11:07 AM
