v vs w rated Kumho tires? - Honda-Tech
Old 07-10-2002, 12:39 PM   #1
Default v vs w rated Kumho tires?
What's the difference between v and w rated tires? I am specifically looking at the Kumho Ecsta 205/50/15 tire on stock 96 GSR rims. v is $58, w is $60. Which has the stiffer sidewall? Will I notice a difference? Thanks!
99civic_exSB is offline   Reply With Quote
Old 07-10-2002, 03:53 PM   #2
Default Re: v vs w rated Kumho tires? (99civic_exSB)
ttt Anyone? V vs W?
Old 07-10-2002, 03:59 PM   #3
speed rating.. do a search on the web or check tirerack.com for the acutal speeds the ratings mean.
chadismo is offline   Reply With Quote
Old 07-10-2002, 06:37 PM   #4
Y2K Si FBP's Avatar
speed rating
v is upto 149
w is upto 168
z is 149 and up
speed rating also tells (most cases) how stiff the sidewall will be..how much heat the tire can hold.
Y2K Si FBP is offline   Reply With Quote
Old 07-10-2002, 08:19 PM   #5
Vazquez911's Avatar
Default Re: v vs w rated Kumho tires? (Y2K Si FBP)
Buy the Ws... when they arrive they are marked as Z's...
I love em... 712s killer price for good performance!
Vazquez911 is offline   Reply With Quote
Old 07-10-2002, 10:48 PM   #6
PatrickGSR94's Avatar
Generally when comparing 2 tires of the same size, the tire w/ the higher speed rating will perform better at all speeds (in the dry at least). i'd go for the W's, can't go wrong for an extra $8.
PatrickGSR94 is offline   Reply With Quote
Old 07-11-2002, 12:07 AM   #7
ALF
ALF's Avatar
The v-rated version has a higher treadwear rating, but will have less overall grip than the w-rated.
Go for the w-rated ones...even those aren't so nice when it comes to handling, but it's better than the v-rated version, nonetheless.
ALF is offline   Reply With Quote
Old 07-11-2002, 10:22 AM   #8
RuskeR's Avatar
Default Re: v vs w rated Kumho tires? (ALF)
Even though your car won't be in the 168mph range I'd still get the w rated tires. It's only $8 bucks. Worth the little extra handling you get.
RuskeR is offline   Reply With Quote
Old 07-11-2002, 10:50 AM   #9
New User
Default Re: v vs w rated Kumho tires? (RuskeR)
I bought the Z rated 712's from http://www.TireRack.com. They were the same price as the lower rated tires. You will be sacrificing a small amount of tread life to get the higher speed rating, but the tires will hold up better under abuse. I am very happy that I got the Z rated ones.
slickboy is offline   Reply With Quote
Old 07-11-2002, 12:15 PM   #10
Default Re: v vs w rated Kumho tires? (slickboy)
So the general consensus seems to be to go with the W's. Any idea how much tread life I'd be sacrificing? Also will the W's be much louder than the V's? Just wondering. Thanks guys!
kumho ecsta 712 v 711 nightrider Acura Integra Type-R 12 11-21-2003 02:50 PM
tire squeeling Raocorp Honda Civic / Del Sol (1992 - 2000) 8 06-22-2003 04:23 AM
Kumho 711 and 712....?? J.P. Honda CRX / EF Civic (1988 - 1991) 11 02-20-2003 10:17 PM
Kumho Ecsta Supra 712, 195/50 15's...H-speed rated vs. V-speed rated? Quik89Si Honda CRX / EF Civic (1988 - 1991) 0 08-05-2002 12:07 PM
Tire question, big difference in grip between V and Z Kumho 712's? HyperREV Honda CRX / EF Civic (1988 - 1991) 2 03-16-2002 12:39 AM
Tags
barbara, difference, dunlop, kuhmo, kumho, rated, rating, ratings, santa, speed, tire, tires, vrated, vrating, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
