unstable steering
Old 11-27-2005, 01:06 PM
Shirozu's Avatar
Default unstable steering
i've only driven the integra a few times on the highway but whenever i pass the 70 mph mark the steering wheel seems to gets unstable a little bit like you have to correct the wheel every minute or so to keep the car going straight. I heard this is normal but i'm not sure. Can someone shed some light on this and what I could improve/upgrade so everything can be more stable? thanks
Old 11-27-2005, 01:20 PM
nitrofish420's Avatar
Default Re: unstable steering (Shirozu)
I would check your tire pressure first of all. Then make sure you don't have any loose front end components (tie rod ends, ball joints, bushings, etc.) and have your alignment checked. I wouldn't call high speed instability normal, as mine is fine.
Old 11-27-2005, 01:32 PM
ProjectLSVTEG's Avatar
Default Re: unstable steering (nitrofish420)
Yeah, start with ur Tire pressure, tie rod ends, ball joints, upper n lower control arm bushings, maybe sway-bar endlinks, everything that controls suspension on your car.
If its lowered its prob out of alignment, and you'll need a camber kit (more often than not) installed in order to do a proper alignment.
I hate alignments at work cuz half the cars that come in have been wrecked, and are impossible to get perfect.... gotta love frame shops!
Old 11-27-2005, 02:28 PM
loudassVTEC's Avatar
Default Re: unstable steering (ProjectLSVTEG)
I don't yet have a camber kit, and when my tires get worn on the inside edge, the steering gets highly unstable, and sensitive. The cornering is pretty good, but straight-line stability is non-existent. I am ordering a camber kit, as well as new wheels and tires with my next paycheck. I can't wait. But check your tire wear, and get it aligned, and inspect your suspension.
Old 11-27-2005, 03:17 PM
Danziver's Avatar
Check your alignment, and when my cv's were going bad i had a problem similar to that.
Madukes
01-18-2010 07:43 PM
obuhmyuh
04-14-2008 10:49 AM
The Bster
12-21-2007 09:44 AM
baiwldrnner
Honda Civic (2001 - 2005)
11-01-2007 09:01 PM
jdmeg9
01-08-2005 03:38 PM
Quick Reply: unstable steering
