uneven tire ware question alignment vs. camber/toe kit
Old 01-18-2013, 06:59 PM
Coopa B18c5's Avatar
Default uneven tire ware question alignment vs. camber/toe kit
hey guys iv been reading and reading and searching every where online about what causes uneven tire wear and ways to fix this problem. via a simple alignment or a camber and toe kit. and its toe that causing this and camber plays a small roll.
Now visibly i have minor negative camber due to lowering my car with tein coils, but i have god awful inside tire ware. please don't flame me for making this thread. i just want to know what do i need to fix this! should i try an alignment
first or do i really need to purchase a camber or tow kit?
I read with a good alignment you can run -2.5 to 3 negative camber!
here is 4 photos of me trying to show my visible negative camber and my tire ware.. (front and rear tires have the same wear) tires have roughly 8-10,000 miles on them
Old 01-18-2013, 07:15 PM
been there done that
doood's Avatar
Default Re: uneven tire ware question alignment vs. camber/toe kit
have you EVER had an alignment since lowering it?
Old 01-18-2013, 07:25 PM
310Integra's Avatar
You need an alignment, to me that looks like toe wear. A little negative camber is good too so just get your car aligned.
Old 01-18-2013, 07:53 PM
The car already was equip with the coils when i bought her not to long ago. (I know this isnt a good reason) but since the day i bought her she drove straight as an arrow so i assumed the alignment was good and just needed a camber kit or something ha..
So you dont think i need any sort of kit? Then whats the point of a toe kit? and a camber kit? just to be able to go lower with out rubbing then?
Old 01-18-2013, 07:58 PM
Tillerdrums88's Avatar
Alignment dude! haha same thing happened to me, the tread on the inside front wheels was so bad I had to replace the tires, and then I went and got a front alignment done, 40 bucks. Definitely worth it! Get it does ASAP, it'll fix the problem. OH, and my teg is slammed too.
Serge L
Suspension & Brakes
03-30-2012 12:26 PM
jdmztrane
07-19-2008 06:20 AM
The Si
Suspension & Brakes
02-05-2007 09:03 PM
E36 Guy
16
04-07-2006 09:58 AM
ALF
08-16-2001 05:47 PM
Quick Reply: uneven tire ware question alignment vs. camber/toe kit
