type r cluster in ls - Honda-Tech
Old 09-16-2008, 08:10 PM   #1
mike integra's Avatar
Default type r cluster in ls
im buy a type r cluster in ebay but im, connect the cluster in my ls and the gauge of the gas dont work much people say u need change 3 cables in arness but i dont know please tell me if u say thanks my integra is 1995
mike integra is offline   Reply With Quote
Old 09-16-2008, 08:44 PM   #2
Kendall's Avatar
You need to use the plastic film PCB from your stock cluster.
Kendall is offline   Reply With Quote
Old 09-16-2008, 08:51 PM   #3
Default Re: (Kendall)
iea i change the plastic but dont work the after cluster are auto but my car now are manual please tell me the how to
Old 09-16-2008, 09:21 PM   #4
Global Moderator
Jimmy's Avatar
Default Re: (mike integra)
Quote:
http://www.honda-tech.com/zerothread?id=1836281
Jimmy is offline   Reply With Quote
Old 09-16-2008, 09:23 PM   #5
XslickwhitetegX's Avatar
it shouldnt matter if your teg is auto or not... I swap my ls asuto cluster for a usdm itr cluster than a ukdm cluster.. If you put the "green film" in correctly and the connections are right the itr cluster should work fine
what kind of issues are you having? the heater gauge isnt working? gotta explain in more detail
XslickwhitetegX is offline   Reply With Quote
Old 09-16-2008, 09:55 PM   #6
Default Re: (XslickwhitetegX)
yea i swap the auto tranny for a b16 tranny and im buy the usdm type r cluster and the gauge of the gas dont work my teg is 95 and im change the green sheet and again dont work, too change the pins and dont work
Old 09-17-2008, 04:45 PM   #7
Default Re: type r cluster in ls (mike integra)
please help meeeeeee!!!!!!
Old 09-17-2008, 05:21 PM   #8
M3Stylz's Avatar
Sounds like you might have a bad cluster. When i did mine it took me one try. Switch the green film thing from behind and it should work no problem.
M3Stylz is offline   Reply With Quote
Old 09-17-2008, 07:25 PM   #9
Default Re: (M3Stylz)
yea.... are you sure your putting on the green film correctly? lol
Old 09-17-2008, 07:29 PM   #10
you have a 98-01 cluster. You can switch the film but the gas gauge wont work. You need to take apart both clusters take the white half of the 94-97 cluster and put it together with the itr gauges and trim. Make sure the 94-97 film stays on the the 94-97 white half. Next you need to take the bulbs that were changed from 97 to 98. They moved the seat belt bulb, the abs bulb and i think the opened door bulb. Take those out because they will light up the wrong notification light. You dont want your /abs light to come on when you open the door. That should fix your problem.
bmwe362006 is offline   Reply With Quote
tail lights wont work? jdmone Honda Civic / Del Sol (1992 - 2000) 14 01-11-2010 03:33 PM
Southern CALI- Registered 2002 Genuine Mugened RHD DC5R Honda Integra Type R MINT B2FiNiTY Vehicles for sale 215 06-14-2008 02:54 PM
STOLEN INTEGRA LAST NIGHT DALLAS AREA red02s2k Acura Integra 22 04-05-2008 06:41 PM
WHY IS MY ACCOUNT NOT WORKING??? B18MOBBER Honda Civic / Del Sol (1992 - 2000) 1 11-28-2007 01:47 PM
>>>>White EK Hatch w/ GSR Motor<<<<So Cal>>>>>Cleeeean. REKOX13 Southern California (Sales) 31 11-06-2007 09:14 PM
Tags
95, 98, automatic, cluster, connect, gauge, gsr, integra, itr, ls, problems, put, type, usdm, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
