Trunk Lid STUCK!
Trunk Lid STUCK!
I can't open my trunk lid. The key won't even turn in the keyhole and when I unlock the doors from the inside, the trunk lid still won't open. What should I do?
Re: Trunk Lid STUCK! (GuCCi_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuCCi_GSR »</TD></TR><TR><TD CLASS="quote"> The key won't even turn in the keyhole and when I unlock the doors from the inside, the trunk lid still won't open. What should I do?</TD></TR></TABLE>
did you mean that little keylock that's on the gas and trunk release levers? if you didn't, try that. if you did then youre screwed!
just kidding. it sounds like your keylock is jammed. get a new one, i guess? can you find the pull-switch from inside the trunk and pull it, see if it opens. if that doesn't work.... last resort is dealership or mechanic. unless ne1 else has ideas?
That has happen to me once, bad actuator. What you want to do is open the hatch manually. Turn the key to the unlock position on the hatch until hear a pop/unlocking sound. Pull the hatch up while still having the key in that position. This should do the trick and get a new actuator.
Re: Trunk Lid STUCK! (00b18b)
i can't even turn the key so that it will open!
is there someway to open the trunk from the inside, by pulling the rear seats down?
p.s. i have a 99 gsr.
PowerUser
03-29-2010 01:47 PM
