Transmission oil drain/filler plug washer question
Old 04-17-2003, 12:28 PM
gsrclan's Avatar
Default Transmission oil drain/filler plug washer question
The manual says you should replace them at every oil change. My question is where to get them? Are they the same as engine oil drain plug washers?
Old 04-17-2003, 12:31 PM
ragejed's Avatar
Default Re: Transmission oil drain/filler plug washer question (gsrclan)
alumminum crush washers. Order like 10 from acura because they dont keep them in stock, and they are cheap. like 20 cents. Auto parts store charged me 2 bux for 1!!! and it was fiber..
Old 04-17-2003, 12:54 PM
Aaron M's Avatar
Default Re: Transmission oil drain/filler plug washer question (ragejed)
the tranny crush washer does not need to be changed every oil change. BUT the oil drain bolt crush washer does.
there 25 cents at my local dealer. i usualy just by 2 everything i go there, even if im not doing an oil change. i have about 6 of them now
tpnorth
07-26-2011 05:24 PM
tjjm36m3
06-21-2008 04:31 PM
SamC
04-11-2006 01:21 PM
RCautoworks
01-04-2003 01:11 PM
Quick Reply: Transmission oil drain/filler plug washer question
