Tranny problem wont go into reverse
I bought a 94 gsr yesterday and brought it home and all the gears shifted fine. I used reverse all the time yesterday and this morning i used reverse 3 times then after i went to go to work it wouldnt go into reverse. No grinds, its not like it clicks into reverse and does not move, I just cant physically put it in reverse. HELP
Re: Tranny problem wont go into reverse (trick_db)
Tryed putting it in reverse from every gear and it wont go in. I figure the fluid is ok since it was workin this morning.
Re: Tranny problem wont go into reverse (str8JDMteggy)
My tranny did that after my second session at Expo 6. I changed MTF and it did nothing. In a pinch and since one was readily available I just got an R tranny. I still haven't looked at it close enough to see what happened but I imagine since I shift a little hard I broke/bent a fork. GL and if you have any pointers for me let me know.
Probaly did the same thing because this happened after my friend took it for a ride and he was hitting the gears hard. Ive checked on the for sale fourm but do you know anywhere i can get a tranny?, LSD would be even better. Thanks in advance.
TREESnoseeds787
02-11-2007 08:55 AM
SonicRacing
02-07-2006 02:49 PM
