lS vtec problems
Old 08-26-2010, 09:41 PM
carlossolorzano's Avatar
Default lS vtec problems
i was wondering y my car only raves up to 5000RPM then i connect my gsr ecu i did ls vtec on my 96 integra ... can it be a sensor or is it that im using ls troudle body... can some one plz help me out.... replay or txt me at (209)303-9174
Old 08-27-2010, 01:35 AM
mouab18c1's Avatar
Default Re: lS vtec problems
What?
Old 08-27-2010, 03:08 PM
i have a 96 ls ,,, i when ls vtec but my vtec is not kicking in i have everything wire up. im using a ls throttle body
Old 08-27-2010, 06:55 PM
Mavi87's Avatar
Old 08-27-2010, 08:07 PM
shocker911's Avatar
ummmm yea....your throttle body has nothing to do with the problem.
1.what ecu?
2.is it wired up right?
3.what head are you using?
4.check engine light?
5. complete thoughts please
Old 08-27-2010, 09:36 PM
is a 98 gsr p72
yes is wired right
im using a 95 gsr head is all obd2 do
Old 08-27-2010, 09:46 PM
mouab18c1's Avatar
95 head is obd1 and you're saying you went ls/vtec not when.
Check oil level. clean vtec solenoid screen. check to make sure you have no CEL.
Old 08-28-2010, 07:30 AM
yea is a 98 block, wit 95 head changed injectors everything to make it obd2
Old 08-28-2010, 10:09 AM
mouab18c1's Avatar
You need to run an obd1 ecu.
Old 08-29-2010, 03:01 PM
so if i connect a obd1 ecu it should run koo? but i changed everything to obd2 alternator, injectors
Old 08-29-2010, 05:09 PM
dc101's Avatar
this dude needs to learn English, I can hardly comprehend what he is saying.
Old 08-29-2010, 09:00 PM
mouab18c1's Avatar
Your whole motor can be obd2. Distributor, injectors, alternator, harness, yada yada. You can still run an obd1 ecu. If its in an obd2 chasis then you will need an ecu conversion harness. I was thinking if your ecu is also a vtec ecu and vtec is not activating then your problem lies else where. Check your wiring or try a different ecu first to see if the problem lies within the ecu.
hamburgler
02-08-2006 01:28 PM
cr9m5
09-29-2005 07:49 PM
Quick Reply: lS vtec problems
