Tires & Rims Fitment
I have a 94 Integra LS. It came with 195-60-14 (23.22 inch diameter) tires & rim combo. I’ve swapped the rims for 205-40-17 (23.46 inch diameter) and also lowered the car with neuspeed sport spring (1.75f/1.5r inch drop) and kyb adjustable. I now want to go back to stock. I got my hands on 2003 si style rims, which came off a 2003 civic ex. The tires & rims combo is 185-65-15 (24.46 inch diameter.) Original Si rims off a 2000 Si came with 195-55-15 (23.44 inch diameter) tires & rims combo.
My question is:
1. Will 2003 si rims fit without rubbing? By looking at it, it is real close? Is the bolt pattern the same?
2. Are the si rims off a 2003 ex the same rims off a 2000 si? If so does that mean I could change the tire size from 185-65 to 195-50.
3. I would like to know also if the si rims and gsr rims are the same bolt pattern? I have gsr rims with 195-50-15 (22.68 inch diameter) tires and rims combo
4. Can the gsr rims fit my ls. I went to a mechanic that fixes only Honda and Acura cars and he said I should just find the original 14 inch rims cause the gsr rims and si rims won’t fit?
I’m puzzled. Enlighten me please.
My question is:
Re: Tires & Rims Fitment (94LSTEG)
I run the GSR rims on my 91 Teg with 205- 50- 15 with no problems at all.
the 65 series tires you have may be a little tall but shouldn't rub.
When all else fails try it out.
Re: Tires & Rims Fitment (BountyHunter)
yes gsr rims will fit into ls without any doubt.but i am afraid that the si looking rims will most likely rub. go back to stock.
94LSTEG
10
05-08-2004 11:39 PM
