Tires for LS Mesh Wheels
Re: Tires for LS Mesh Wheels (jtintegra)
assuming stock tire size of 195/55/15 on that rim....
205/50/15 will throw off your speedo a little bit (actual speed a little lower than what speedo says)
215/50/15...basically no speedo error. what speedo says is what you are going.
with the 205/45/15 will throw your speedo off more than the 205/50....you'll be a few miles an hour slower than what the speedo says.
in order to have no speedo error if you wanted a 45 series tire....you'd need a 235 wide tire....good luck fitting that one....
[Modified by fivespeedintegra, 11:10 PM 1/20/2003]
[Modified by fivespeedintegra, 11:11 PM 1/20/2003]
k3ntegra
04-10-2014 07:34 PM
