Tips for taking off stuck oil filter
Old 09-17-2002, 10:07 PM
  #26
Mr.Rab's Avatar
Default Re: Tips for taking off stuck oil filter (redteg1)
When I couldn't get my oil filter off the first time when I was changing my oil and the cheap *** oil wrench would not grip, I said **** it and got the honda oil cap. Works like a charm.
Just got a digi cam so I'm going crazy with it.
Old 09-17-2002, 10:11 PM
  #27
Ferrell's Avatar
Default Re: Tips for taking off stuck oil filter (ExOdy)
Punch a screw driver into it and unscrew.
worked like a charm my first oil change
Old 09-17-2002, 10:29 PM
  #28
brinks's Avatar
Default Re: Tips for taking off stuck oil filter (Halo)
Screwdriver is a risky move. if you tear the outer part of the filter, there is no way it will come off. I will never use that method again.
Old 09-17-2002, 11:12 PM
  #29
New User
Mr. Choi's Avatar
everyone who has suggested using a sandpaper knows their ****.
sandpaper is the way to get that thing off. a 200 grit sandpaper always
works for me. jus make sure you are far enough under the car so you
can get some leverage. i usually go as far as my belly button area near
the control arm. GET YOUR *** WAY IN THERE. you'll get that **** out.
SANDPAPER!!!
Old 09-17-2002, 11:24 PM
  #30
Volcom's Avatar
Default Re: Tips for taking off stuck oil filter (Dr. RAB01GSR)
Nice desk and filter
Nice camera
Old 09-18-2002, 12:20 AM
  #31
keys's Avatar
Default Re: Tips for taking off stuck oil filter (keys)
damn I sure wish I knew about the sandpaper method before I stabbed my filter. Has anyone ever done or heard of anyone doing any damage to the engine block using the screwdriver stab method?
So I'm guessing no one has ever damaged their block or heard of anyone damaging their block using the screwdriver stab method?
BTW nice camera, what kind is it?
Old 09-25-2002, 06:22 PM
  #32
keys's Avatar
Old 09-25-2002, 07:32 PM
  #33
Y2K Si FBP's Avatar
if i can't get mine off..i always use a wide rubberband or two..almost always does the trick
Old 09-25-2002, 10:11 PM
  #34
Cramerox's Avatar
Default Re: Tips for taking off stuck oil filter (Y2K Si FBP)
sandpaper
Old 09-26-2002, 07:10 AM
  #35
SiMugen's Avatar
Default Re: Tips for taking off stuck oil filter (Cramerox)
Leather Belt works miracles, definatley give it a try.
Screw Driver
Old 09-26-2002, 10:46 AM
  #36
Rory Breaker's Avatar
Default Re: Tips for taking off stuck oil filter (SiMugen)
Leather belt works, but I've snapped a few before on cars that are factory tightened. Filter wrenches work great if you can fit it on the filter.
Sandpaper or a nice mechanic's glove also will make a tough filter a ton easier to pop off.
Old 09-26-2002, 10:55 AM
  #37
backlash's Avatar
That's what I had to do when I did my very first oil change on my car.
Old 09-26-2002, 11:53 AM
  #38
New User
wuhungsixxx's Avatar
Default Re: Tips for taking off stuck oil filter (backlash)
i used my man hands...took me nearly 15mins to get it off...my wrist was sore for the next day...POS!
mrchevez
08-07-2008 02:52 PM
ninety-five_DB
07-08-2006 05:03 PM
Understeer
06-07-2003 10:58 AM
no_limit
08-02-2001 03:44 AM
Type Goch
07-01-2001 10:11 AM
Quick Reply: Tips for taking off stuck oil filter
