Tips for more low end power..
I have a 1999 Acura Integra LS and noticed that the power band in the low end is really dead compared to the top end. Once the RPMS get high the top end screams power. The only mods I have are a AEM Short Ram and was wondering what you guys think I should get to produce more power in the low end.
Thank You VERY much
Thank You VERY much
Re: Tips for more low end power.. (Integra Integra)
it's a honda....they are NOT made to make power in the low end. You would actually have to downgrade you cams and make your valves smaller to make that extra torque in the low end. Just down shift and get those revs up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra »</TD></TR><TR><TD CLASS="quote">Thanks for the suggestions but I am talking about something more affordable maybe some headers or exhaust?</TD></TR></TABLE>.
you have a 4 cylinder, you only need one header
Low end power in a 1.8 liter doesn't exist. If you want low end power, either spend big bucks and get the supercharger, get a different car, or when you launch, get yours RPMS up to 6,000. You could kiss your axels and a whole host of other things goodbye with that last plan though.
go try the venom 400 module that increases your torque from 1000-5000rpm, dunno if it works its only like $300, go try that it might help, let me know if it works!
oh i forgot to tell you to get this... this definately works i got it in my car and i felt the powerband climb up quicker in 1st, 2nd, 3rd gear.... its called a GROUND STABILIZER i got the brand E-POWER
Global Moderator
Re: Tips for more low end power.. (dvs gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvs gsr »</TD></TR><TR><TD CLASS="quote">go try the venom 400 module that increases your torque from 1000-5000rpm, dunno if it works its only like $300, go try that it might help, let me know if it works!</TD></TR></TABLE>
Worst advice. Ever.
Worst advice. Ever.
Re: (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC »</TD></TR><TR><TD CLASS="quote">Get a stroker kit!! Make that LS a 2.3L, then you'll have some low-end grunt, along with crazy top end power!! </TD></TR></TABLE>
if you consider 5500 RPM "top end"
A low-displacement 4cyl doesn't produce low-end power. Unless you supercharge it... but you'll still peak at high rpm's anyway.
Re: Tips for more low end power.. (StatGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StatGSR »</TD></TR><TR><TD CLASS="quote">i noticed improved low end power with my 4-2-1 header... not a lot, but noticiable...</TD></TR></TABLE>
Umm....Problem with that stament is it isn't true. By opening up your exhaust you actually LOST Torque and HP in the low end to benefit the high end flow. Read up and you'll realize that I'm right, hence you don't want to go too big on exhausts if you are N/A. I know it's hard to believe, but bigger is not better when you are talking about low end.
Re: Tips for more low end power.. (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">
Umm....Problem with that stament is it isn't true. By opening up your exhaust you actually LOST Torque and HP in the low end to benefit the high end flow. Read up and you'll realize that I'm right, hence you don't want to go too big on exhausts if you are N/A. I know it's hard to believe, but bigger is not better when you are talking about low end.</TD></TR></TABLE>
and since you and i both know that hondas dont make low end power PERIOD, there is no point trying to make a mean low end HONDA
Re: (Zach GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zach GSR »</TD></TR><TR><TD CLASS="quote">A light weight flywheel will liven things up a bit. It did on my GSR.</TD></TR></TABLE>
true, you dont gain power, but the car sure as hell is more fun to drive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">it's a honda....they are NOT made to make power in the low end. You would actually have to downgrade you cams and make your valves smaller to make that extra torque in the low end. Just down shift and get those revs up </TD></TR></TABLE>
TRUE SO TRUE
How much low end power did you gain???
LOL
AEM Cold Air Intake System DC Sports 4-1 or 4-2-1 Ceramic Header
$419.00 For LS! Go for it!
TRUE SO TRUE
LOL
an apexi ws2 is as good as a stock exhaust, barely any noticable gains. Even though that exhaust should give you good low-mid gains due to the small backpressure it gives vs a straight through, i felt nothing. You should get a short ram intake + 4-2-1 headers for that mid range.
