timing belt tensioner what size is it??? - Honda-Tech
Old 08-23-2007, 04:47 PM   #1
killacam661's Avatar
Default timing belt tensioner what size is it???
like title says..... and i cant get my belt on without loosening the tensioner.....right? any suggestions i just pulled the head off now need to put the timing belt back on.
killacam661 is offline   Reply With Quote
Old 08-23-2007, 05:33 PM   #2
non-VTEC's Avatar
Default Re: timing belt tensioner what size is it??? (killacam661)
good luck trying to slip that belt on without undoing the tensioner.........just do it properly......i can guarantee you will fight with it over an hour before figuring out it's easier to take 5 minutes to undo the tensioner and time it properly....
non-VTEC is offline   Reply With Quote
Old 08-23-2007, 05:36 PM   #3
Default Re: timing belt tensioner what size is it??? (non-VTEC)
Quote:
thats why i was asking what size it is. i heard it was a 14mm bit mine looks to be a 17mm. and without taking the cover off i cant access the tensioner. i wasnt asking for a shortcut.
Old 08-23-2007, 09:17 PM   #4
ttt soemone know quit bein lazy
Old 08-23-2007, 09:47 PM   #5
BLacK FirE's Avatar
yes it is a 14mm.
BLacK FirE is offline   Reply With Quote
Old 08-23-2007, 11:12 PM   #6
Default Re: timing belt tensioner what size is it??? (BLacK FirE)
Quote:
Originally Posted by BLacK FirE
yes it is a 14mm.
hmmmm mine has like a 16 1/2 mm bolt ..... to big for 17mm and 11/16 ....and 16mm and 5/8 were too small. i dont know what size it is and i dont want to round it off. its a wierd *** size and i dont know why theres not a 14mm bolt on the tensioner. gay!!!!
vtec ayday
Quick timing belt question... Tims Toy 500 Honda CRX / EF Civic (1988 - 1991) 2 08-11-2013 12:07 PM
cant get tension on belt tensioner Deviant117 Honda Accord (1990 - 2002) 4 03-28-2011 10:23 AM
Belt tensioner Hittnthebz Honda Civic / Del Sol (1992 - 2000) 3 01-18-2008 02:27 PM
How do I tension the timing belt??? -Gambit- Honda Civic / Del Sol (1992 - 2000) 2 11-13-2005 05:13 PM
H22 timing belt tension petrv Honda Prelude 5 06-20-2003 01:23 PM
Tags
1994, 2002, belt, bolt, civic, diameter, dimensions, honda, integra, size, sizes, tensioner, timing, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
