Timing Belt with Stage 2 Skunk Cams?????
I plan on getting the stage 2 cams from skunk and was wondering if I would have a problem with the shortened life of the timing belt with these. I am replacing my timing belt since it broke and just want to know if my timing belt would be affected by the new cams?? any info would help. I know some of you say that with Toda spec B cams the timing belt only last about 40K miles.
Re: Timing Belt with Stage 2 Skunk Cams????? (hybridreams)
Yeah that is true, but why are people having problems with the toda spec b cams. Why does it wear out the timing belt sooner??
Re: Timing Belt with Stage 2 Skunk Cams????? (AK94GSR)
Because when you compare the primary/secondary lobes of the toda spec B cam, they almost look identical to the VTEC lobe. So this is almost like having vtec on ALL the time. Just run a brand new stock belt and change it more often.
Re: Timing Belt with Stage 2 Skunk Cams????? (TSK)
Geta power enterprise belt and be safe rather than sorry....Timing belts usually snap on B's due to improper installation and maintinence. Also running a valve cove w cam gear cut outs will cause deterioration. Get one for the dyno and keep them covered on the street.
nEoMuGen
01-10-2004 02:24 PM
JSIR
05-10-2002 07:54 PM
