95 Gsr cranks doesnt start
Old 06-29-2012, 03:14 PM
ironiceghatch's Avatar
Icon6 95 Gsr cranks doesnt start
Alright the other day I came out of work and started my 95 Integra Gsr sedan and it fired right up and shut right back off. It cranked but did not start. While I was stuck at work I had the gf bring a spare main relay I had to try that and no luck. Then I went home and pulled my dizzy off of my b16 civic coupe and tried that with no luck. I just got it home today and checked for spark and fuel. I have fuel but no spark. Well I know that dizzy off the coupe is good so I was confused. Checked the timing belt and its a little loose but nothing crazy. Had my buddy crank it over while looking at the timing belt and the crank is spinning and the alternator belt is spinning BUT the TIMING BELT IS NOT SPINNING.
Plan on changing the timing belt tomorrow but im curious if the tensioner could also be part of the problem? Also I had been cranking it over quite a lot and am wondering if I might have bent a few valves?? how likely do you think this is?
Old 06-29-2012, 03:21 PM
DCAR's Avatar
Default Re: 95 Gsr cranks doesnt start
will the bottomend turn by hand "with a 1/2 drive strong am"? might wanna drain the oil to see if there is any metal shavings in there. that would be the next steps. make sure this not locked up.
Old 06-29-2012, 03:24 PM
Icon6 Re: 95 Gsr cranks doesnt start
the crank does spin. Im gonna mess with it more tomorrow and check for metal shavings
Old 06-29-2012, 03:28 PM
cagedGSR's Avatar
sounds like the belt might be missing teeth, and it started and ran until the timing belt hit the patch where there are no teeth, hence why crank spins and belt does not.
Old 06-29-2012, 03:40 PM
ya thats what I figured even though the timing belt looks good as far as i can see. Im just wondering if it might also be a faulty/seized tensioner
Old 06-29-2012, 03:53 PM
cagedGSR's Avatar
even if the tensioner was siezed the teeth on the belt would still make it spin, the car would drag and you'd smell burnt rubber.
Old 06-30-2012, 06:43 AM
b20c5eg's Avatar
I have had a few timing belts brake on b series motors and only one of them bent valves. all the other ones luckly were ok. I say throw a belt and tensioner at it. I would be silly to not replaced the tensioner even if it looks good. You might want to go ahead and change the water pump and the front crank and cam seals while youre in there. good luck either way
Jdbdkid93
15
01-25-2021 05:20 PM
ddn1313
08-04-2018 02:46 PM
Macnotiss
10
10-18-2017 05:44 PM
Jack Shephard
12
02-13-2009 06:27 PM
rokestah
02-03-2003 04:20 PM
Quick Reply: 95 Gsr cranks doesnt start
