Timing belt cover for a b20 vtec. - Honda-Tech
Old 01-27-2014, 07:22 PM   #1
MegustaVtec's Avatar
Icon2 Timing belt cover for a b20 vtec.
Can anyone share from what motor timing belt covers can be use on a b20vtec with a b16 head. I have been looking around and I hear different comments. Can I use all gsr covers. Or b20 bottom and both b16 upper covers.
MegustaVtec is offline   Reply With Quote
Old 01-27-2014, 07:25 PM   #2
B_Swapped93's Avatar
Default Re: Timing belt cover for a b20 vtec.
Quote:
Any year b20 block cover and any year vtec b-series upper
B_Swapped93 is online now   Reply With Quote
Old 01-28-2014, 06:35 AM   #3
any obd2 lower cover (if using pump with ckf sensor provisions). GSR/ITR upper covers. You will have to shave some off the back of the inner cover if you want that to fit.
kyden is offline   Reply With Quote
Old 01-31-2014, 03:23 PM   #4
Quote:
the bottom block is jdm. what if I use a the upper covers from a 2000 si. do I have to shave the back to make it fit.
Old 01-31-2014, 03:52 PM   #5
I am Jack's...
Tyler Dirden's Avatar
Here's the facts:
There is very little effort to make the complete timing set work and fit excellent. The pictures show a tiny little tab that gets removed from the block rear cover and a tiny slot made for a rib on the motor as shown. Afterwards it will fit excellent and allign almost perfect with the upper cover except for a very small, nearly unnoticable gap on the rear where they are meeting with the water pump. Not a gap really, just spread apart slightly, but fits with all the hardware fine.
Tyler Dirden is offline   Reply With Quote
Old 01-31-2014, 04:06 PM   #6
thanks for the pictures. those covers are from a gsr/type r.
Timing Belt Cover B20VSi2000 Tech / Misc 0 05-11-2016 10:45 PM
honda parts jeffcool3 For Sale 0 05-02-2010 08:52 PM
B series timing belt covers , which to use mitsuman Hybrid / Engine Swaps 4 12-21-2007 03:18 PM
B20 vtec upper timing belt cover Tarmac Junkie Tech / Misc 4 10-02-2006 10:07 AM
timing cover OBD2 gsr what will work 1QwIkEf Tech / Misc 1 05-26-2005 08:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
