timing belt adjustment - Honda-Tech
Old 07-12-2008, 01:54 PM   #1
danteisme's Avatar
Default timing belt adjustment
so my timing belt is pretty loose after replacing it, the water pump, and tensioner. there is almost and inch and an eight of deflection on the exhaust side. obviously that side will have the most slack cuz its the longest part without being on another pulley or whatever. i was reading the manual on how to adjust it, i just wanna make sure im understanding what they're saying. heres what it says
obviously take the vc off
1. set no.1 to TDC
2. roate the crankshaft 5-6 revolutions to set belt
3. then set no. 1 to tdc again
4. loosen adjustment bolt(tensioner) 1/2 turn
5. this is whre im slightly confused..it says rotate the crankshaft counterclockwise 3 teeth on the camshaft pulley. so im assuming i just rotate the crank til i count 3 teeth go by on one of the cams?
6. tighten bolt and done
danteisme is offline   Reply With Quote
Old 07-13-2008, 05:36 AM   #2
Default Re: timing belt adjustment (danteisme)
You're correct, as you turn the crank slightly the cams add tension to the belt since they're trying to pushing open some valves.
Since your belt has been running for a while I would just do steps 3-6. It's pretty obvious if you do it right, belt will be nice and tight.
Suggestion, don't drive the car until you retension the belt.
stumpyf4 is offline   Reply With Quote
Old 07-13-2008, 07:34 AM   #3
ACTION JACTION's Avatar
Sometimes this method doesnt work as it didnt work for me so I had to do the coat hanger technique.
Take a metal coat hanger and make one end into a fish hook. Loosen the tensioner and then hook it with the coat hanger and pull up on it till you get enough tension, then tighten it.
ACTION JACTION is offline   Reply With Quote
Old 07-13-2008, 08:34 AM   #4
letsdrive's Avatar
youre supposed to leave the tensioner bolt loose when you do the 5-6 rotations . Bring it back to tdc then tighten it then rotate it three teeth ccw, then you loosen it and youll see the slack tighten from the tensioner. then you tighten the tensioner bolt to 45 ft/lbs.
letsdrive is offline   Reply With Quote
Old 07-13-2008, 05:08 PM   #5
Default Re: (letsdrive)
Quote:
Negative. Re-read your manual. Try rotating the crank with the tensioner bolt loose, guaranteed to skip a tooth or more.
Quote from the manual for tensioning the belt (1998 Integra page 6-9)
1) Remove the cylinder head cover.
2) Set the No. 1 piston at TDC
3) Rotate the crankshaft five to six revolutions to set the belt.
4) Set the No. 1 piston at TDC
5) Loosen the adjusting bolt 1/2 turn (180deg) only.
6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley.
7) Tighten the adjusting bolt to the specified torque.
8) After adjusting, retorque the crankshaft pulley bolt to 177Nm.
Old 07-13-2008, 06:35 PM   #6
danteisme's Avatar
Default Re: (stumpyf4)
Quote:
yeah thats what i was thinking, i figured i'd wait to see what other people said first
Old 07-14-2008, 05:45 PM   #7
letsdrive's Avatar
i meant have it tight. hands didnt write what brain meant.
Old 07-02-2009, 05:43 PM   #8
New User
what way am i supposed to rotate the tensioner bolt to loosen it up? ive been trying for a long time to loosen up the belt to get in back onto the pulleys... but the more i do it the more the bolt gets rounded.
enriquediaz is offline   Reply With Quote
Old 07-03-2009, 09:29 AM   #9
hmoobhero's Avatar
Quote:
common rule. "lefty loosely" "righty tighty".
hmoobhero is offline   Reply With Quote
Old 07-17-2009, 03:41 AM   #10
skhell's Avatar
Hi!
When we turn the crank pulley 3 teeth on the cam pulley, the belt gets more tensioned or less tensioned?
To understand better my question, imagine we would only loosen the adjuster bolt, and tightened it, the belt would be with more or with less tension that when rotating the cam 3 teeth?
skhell is offline   Reply With Quote
Old 08-25-2009, 03:56 PM   #11
New User
Hi...
I have found the timming belt a quite loose.
retightening as adivised in workshop manual created a grind sound in some of the pulleys... or water pump
then i did the same rotating only one teeth and the wierd sound decreased to bare nothing.
i mean... Retightening a belt that has 50k (km) on it... didnt work as expected
so i had to draw back and now even though the belt when cold vibrated a little it works straight when normal temperature...
i supose that this is water pump bearings going away... 160 k needing a new one
can you give any advise about this?
Thanks
PS: boas skhell tudo bem? lol tuga do catano.
RicardoPTmax is offline   Reply With Quote
Old 08-25-2009, 04:04 PM   #12
New User
Quote:
Originally Posted by skhell View Post
Hi!
olá
quando rodas a cambota... a correia estica de um lado.. e do outro o tensor acança para a posição normal e é fixo ai ao aparafusar a porca.
mas isso é valido para correias novas apenas... n podes fazer os 3 dentes com uma correia usada. suponho.. pelo menos foi o que fiz
é normal que haja algum barulho durante primeira semana. ate que ela estique um pouco para o tamanho e tensao normal.
(english)
hi... when you turn the crankshaft the belt stretches in one side while in the other the tensioner pulley advances reduces it slack and when you tighten the bolt, it stays in the proper position.
thing is ------- that it is valid to new belts only.. old betls... cant do the 3 teeth must be less i guess... that what i did.
it is natural that some noise pulley might be heardable in the first week or so a until it streaches a bit to normal state.
Old 08-31-2009, 04:18 AM   #13
skhell's Avatar
Quote:
Originally Posted by RicardoPTmax View Post
Hi...
Thanks
Maravilha, não sou o unico tuga por aqui eheheh
Well, I always thought that the procedure of setting the right amount of tension would apply to a old belt, after all, timing belts are not supposed to stretch over the time... Any way, your experience with this is very helpfull, thank you so much, that thing of rotating it only one tooth is a good idea, the problem is if it got with less tension than it should...
Old 09-21-2009, 01:10 AM   #14
8OOSTED's Avatar
How do I get to the tensioner bolt? Do I have to remove the entire timing belt cover? My friends told me I could do it without removing all that but I can't figure out how.
PS: I have a 94' LS
8OOSTED is offline   Reply With Quote
Old 09-21-2009, 07:12 AM   #15
danteisme's Avatar
Quote:
PS: I have a 94' LS
its been a while since i did this, but i believe there is a plug in the timing cover you can pop out and gain access to the bolt. just dont over loosen it or you might be screwed.
Timing belt walk (please help!!) CptHMCrunch Honda Prelude 6 02-12-2017 03:24 PM
Rotate 3 teeth? - Timing belt tension lllelementlll Acura Integra 4 10-15-2016 05:49 PM
turn engine wrong way a little okay? sgull Honda Accord (1990 - 2002) 7 07-07-2013 07:59 PM
Correct Method for Timing Belt Tension yosuthnmasa Honda Civic / Del Sol (1992 - 2000) 8 04-08-2008 08:29 AM
timing belt either too tight or too loose 89sparks All Motor / Naturally Aspirated 3 08-31-2007 07:27 PM
Tags
1985, 99, adjuster, adjustment, belt, f4i, integra, loosen, prelude, skip, teeth, tension, tighten, timing, tooth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
