Tie Rod/alignment question
Old 11-18-2012, 10:11 PM
jonyi27's Avatar
Default Tie Rod/alignment question
So my driver side inner tie rod needs replacing so I'm changing my inner/outer tie rod, so I was wondering if I get the right thread count or get it close enough (outer tie rod connecting to the inner tie rod) is it necessary to get a alignment right after.... Even if the steering wheel sits straight?.... Money is tight.. The string alignment is confusing to me so let me know please and thank you
Old 11-18-2012, 10:13 PM
jonyi27's Avatar
Default Re: Tie Rod/alignment question
And if I take it to a professional how much would he charge to change it.. And do they do the alignment since there changing the tie rod
Old 11-19-2012, 09:46 AM
jonyi27's Avatar
Anyone?
Old 11-19-2012, 09:58 AM
jonyi27's Avatar
Anyone?
Old 11-19-2012, 11:09 AM
vtaker's Avatar
Are both tie rods exactly the same dimensions? If not, then counting threads wont matter. I would seriously just pay the $50 and get it aligned properly. The steering wheel might be straight, drive straight and you could still have a toe problem.
If you had a shop do it, I'm guessing $250. You should call around and get some quick quotes.
Old 11-19-2012, 11:22 AM
fcm
Old Fart
fcm's Avatar
Anytime anything is done to suspension or steering a wheel alignment is needed. 94
Old 11-19-2012, 03:26 PM
jonyi27's Avatar
Guess change the tie rod myself then just get it aligned for the winter... But what and where? Is the "toe" that needs to get aligned...
But in my old integra my friends step dad changed the tie rods and I didn't get it aligned and I drove it for a while and it didn't give me any problems
Old 11-19-2012, 03:30 PM
vtaker's Avatar
Toe is the adjustment of your tie rods. If you don't get it right, the car might not drive straight and the tires will wear unevenly. Toe is all you can adjust on a stock integra. Camber and Caster can only be adjusted with special aftermarket suspension parts.
Fliptard's Avatar
just unbolt the inner and outer and take both off together!!! do not separate them, then measure from the face of the inner to the bolt on the outer, screw the 2 new ones together, and get them the same as your old ones and it'll be really close.
I'd still get it aligned tho
Old 11-19-2012, 03:52 PM
jonyi27's Avatar
Yeah my suspension is pretty much stock other the tokico blue shocks
Old 11-19-2012, 04:23 PM
fcm
Old Fart
fcm's Avatar
Not entirely true, although camber is "fixed" camber is adjusted with shims, Caster on the other hand is not adjustable without installing adjustable radios rods. 94
Old 11-19-2012, 05:10 PM
jonyi27's Avatar
Grease gun do I need it... Cause I don't own one nor I know someone with it why do I need it I can't use regular grease and spread it with my hand?
Old 11-20-2012, 01:01 AM
jonyi27's Avatar
So anyone know about the grease gun or just plain grease I need to know ASAP doing it in the morning.... Or is the inner tie rod already pre-greased and don't need anything?
Old 11-20-2012, 01:16 AM
HondaGuy1989's Avatar
If it has a zerk fitting your golden. Always try and replace your control and steering components with serviceable parts. I suggest using a grease gun with a waterproof grease. They do come with some grease but its not enough to keep the part going for years. Always talk with your local parts store and ask questions! If they don't give you the time....don't give them the money!
Old 11-20-2012, 09:34 AM
jonyi27's Avatar
What's a zerk fitting?
Old 11-20-2012, 02:20 PM
jonyi27's Avatar
So can I use regular grease by hand not grease gun?.??
Old 11-20-2012, 03:09 PM
fcm
Old Fart
fcm's Avatar
"What's a zerk fitting?"
http://www.saeproducts.com/grease-fi...FYp_QgodXFwA3w
More commonly called a grease nipple. 94
Old 11-20-2012, 09:23 PM
jdmunlimited1's Avatar
Just do the work and take it to a shop and pay at most $70 to get it aligned.
It may look straight but it wont be and you will probably pay for it later.
LeathaFace
03-27-2015 03:16 PM
Charri
10-18-2007 03:28 AM
alleyezonme
Suspension & Brakes
08-09-2005 05:09 PM
crxgator
16
04-30-2004 06:14 PM
mr_mbuna
07-31-2002 12:11 PM
Quick Reply: Tie Rod/alignment question
