Thumping noise coming from axle
Old 10-14-2007, 09:36 PM
dc2doi's Avatar
Default Thumping noise coming from axle
I got this thumping noise coming from the driver side axle.
The axle was just replaced 200 miles ago.
No CV boot are torn.
Lower control arm ball joint has about 2mm of play.
I had the car on jack stands, turn the wheel all the way to the left.
Step on the gas and heard the thumping noise, when its straight
there is no noise or to the right. There were no tires on.
Driving the car I would hear the thumping always.
Could it be a bad axle? mid shaft? could the ball joint be causing this?
Old 10-14-2007, 09:39 PM
Duane_in_Japan's Avatar
Default Re: Thumping noise coming from axle (dc2doi)
CV joint or hub bearing, would not be the first time a bad rebuilt joint was sold.
Old 10-15-2007, 12:28 AM
dc2doi's Avatar
bed time bump.
Old 10-15-2007, 06:23 AM
italianchooch88's Avatar
id guess wheel bearing..
Old 10-15-2007, 07:03 AM
weavertime1's Avatar
Sounds like a wheel bearing. You could always check it with a mechanics stethoscope on jack stands with the wheel off. It will def. make an obnoxious noise through the stethoscope if it is the bearing. Also, drive the car and turn the wheel left and right while driving down the road. Make sure no one is coming obviously. If it is the wheel bearing it will go away when you turn away and return when you straighten out. Good Luck!!!
Old 10-15-2007, 07:05 AM
Also, as Duane_in_Japan stated, It is very possible to have a new CV bad. My dad owns a garage, and we see it 1 out of every 25 or so.
Old 10-15-2007, 11:02 AM
dc2doi's Avatar
When I turn left its quieter. So lets say I turn left which side could this be?
Old 10-15-2007, 11:08 AM
dizzzane's Avatar
Default Re: (dc2doi)
Generally its the opposite way you turn the wheel (it stretches the axle when your turn it opposite)
Old 10-15-2007, 11:23 AM
Default Re: (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">Generally its the opposite way you turn the wheel (it stretches the axle when your turn it opposite) </TD></TR></TABLE>
Agreed...usually its the opposite one of the way you turn. To be sure I always use the stethoscope.
tobytigger
01-11-2014 01:41 PM
Knightrider03m
05-29-2013 05:06 AM
SHystrdyGSRtdy
03-04-2013 01:24 PM
Steve LeB
10-28-2011 11:58 PM
fstgsr
10-29-2003 09:03 AM
Quick Reply: Thumping noise coming from axle
