things to do for 120,000 mile service?
Old 02-26-2003, 11:31 AM
trustbuddy's Avatar
Default things to do for 120,000 mile service?
up to now the things i can think of that needs to be changed/inspected are
1.oil and filter
2.air filter (but i have a k&n, so just cleaning)
3.spark plugs
4.inspect breaks
5.fuel filter
6.tire rotation
7.chek radiator, power steering, and break fluids
8.tranny fluid
anything else?
Old 02-26-2003, 11:32 AM
Eva01's Avatar
Default Re: things to do for 120,000 mile service? (trustbuddy)
9. Valve Adjustment
Old 02-26-2003, 11:56 AM
Diego Boost's Avatar
Default Re: things to do for 120,000 mile service? (Eva01)
1. Sell your car.
Old 02-26-2003, 12:02 PM
tC_Dragon's Avatar
- Inspect PCV valve
- Replace brake fluid not top off.
- inpect tire wear.
- Cap & Rotor (I'm sure it wouldn't hurt to change this)
Old 02-26-2003, 12:17 PM
Eva01's Avatar
Default Re: things to do for 120,000 mile service? (pdcdragon)
30k/60k/90k mile service
Change Engine Oil & Filter
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Distributor cap, rotor and inspect wires
set ignition timing and adjust cambelt
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Replace brake fluid, check hoses & lines
adjust parking brake
replace clutch fluid, clutch operation, adjust freeplay
adjust all belts & inspect power steering fluid
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
replace engine coolant & check hoses belts
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and windshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
Here is a more complete list from one of the few useful posts by Soup ****.
nukem384
03-16-2010 07:20 AM
Convert
13
02-28-2008 12:17 PM
SonicGSR
10-09-2002 08:16 PM
SonicGSR
10-09-2002 07:28 PM
InfamousRS
10-05-2001 09:55 PM
Quick Reply: things to do for 120,000 mile service?
