GSR crank and LS crank the same?
Old 08-29-2006, 08:18 AM
btech's Avatar
Default GSR crank and LS crank the same?
are these two crank the same? looking to get my ls to rev to at least 8k and was told that i would need to replace my crank also?
Old 08-29-2006, 08:30 AM
Semper Fidelis
SlammedDC2's Avatar
Default Re: GSR crank and LS crank the same? (btech)
They are not the same, I believe that the LS has a longer stroke.
Old 08-29-2006, 08:59 AM
IHTFP's Avatar
Default Re: GSR crank and LS crank the same? (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">They are not the same, I believe that the LS has a longer stroke.</TD></TR></TABLE>
true..
ls=89mm
gsr=87mm
and to get your ls to rev to 8k you need an ecu, capable valvetrain and arp rodbolts and headstuds to be safe
you dont need to replace your crank
Old 08-29-2006, 09:44 AM
btech's Avatar
Default Re: GSR crank and LS crank the same? (IHTFP)
would replacing my crank do any good or bad?
yes, i am replacing my rod, piston, and valve train.
i have hondata and its turbocharged.
1SLaMMeDC2
07-22-2010 10:14 AM
85mmek9
12-15-2007 05:55 AM
Quick Reply: GSR crank and LS crank the same?
