Symptoms of bad spark plugs ( not wires) ??
Re: Symptoms of bad spark plugs ( not wires) ?? (matmcg)
... Just check the color on the tip and if its properly gapped. Other then that I don't know how.... maybe misfiring and what not.
Cuz my car wont start
Changed my Dizzy
Main relay is okay
checked fuses
Checked for spark from wires
Got it started one time and it really really idled badly was shaking alot tried to drive and it turned off
sometimes it semi starts but when pressing the gas to try to keep it alive it get weak and dies
Changed my Dizzy
Main relay is okay
checked fuses
Daisy... Daisy...
Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg »</TD></TR><TR><TD CLASS="quote">how do i check the timing?</TD></TR></TABLE>
http://www.c-speedracing.com/h...g.php
Things to ask yourself:
Does the fuel pump always prime? (You should hear a slight buzz from the rear right after the key is turned to the run position but the car is not cranked.)
Are all of your injectors firing? Are the plugs gas soaked?
micah13x
11
04-14-2011 03:09 PM
