Symptoms of a bad ignition switch? - Honda-Tech
Old 06-07-2011, 03:40 PM   #1
Default Symptoms of a bad ignition switch?
Hi, my 98 teg wont start at times. So im thinking it can be the ignition switch. But what are some of the signs of it being bad? Like appearance and things of that sort. Thanks
ezcape is offline   Reply With Quote
Old 06-07-2011, 08:22 PM   #2
Bloody Arro's Avatar
Default Re: Symptoms of a bad ignition switch?
Are you sure it's not the starter?
Bloody Arro is offline   Reply With Quote
Old 06-07-2011, 11:21 PM   #3
Search these forums for ignition switch, main relay, starter.. and see if you can discern the symptoms and diagnostics for each.
You haven't given us much information to work with. For example - does *anything* happen when you turn on the key (hint - activity with lights in the instrument cluster)? Any relays click? Fuel pump run for a second or two? ABS cycle? Hear a loud click when you turn the key to 'start' but no turning of the engine? Engine spinning but no 'fire'?
Those details will help nail down where the problem lies..
Mark
mark@silbernage is offline   Reply With Quote
Old 06-08-2011, 06:01 AM   #4
Thanks for advice and stuff, but i'm simply asking the symptoms of a bad switch. Not looking to get answers of why my car won't start. But i took a look at the switch yesterday and took a picture. Would this call for a replacement?
Old 06-08-2011, 08:49 AM   #5
No, that's just oxidation and wear from the pot-metal part of the ignition assembly.
The place where the attention is needed is inside.. you can clean the contacts and re-lube them if you're so inclined. There seems to be significant current passing through the contacts, and they arc and become pitted over time.
There are articles here (and elsewhere) describing the process; seems fairly straightforward and doesn't require special tools (etc).
Mark
Old 06-08-2011, 05:44 PM   #6
ninjaturtleEG's Avatar
When my ignition switch went bad, there would be a pause when i turned the key to the start position. nothing would happen for a few seconds and then it would start right up. the pause started getting longer and longer. And then eventually when i turned the key to start, nothing would happen at all, the dash lights didnt even come on. But if i remember correctly i think the starter relay was still clicking.
ninjaturtleEG is offline   Reply With Quote
Old 06-08-2011, 05:52 PM   #7
fcm
Old Fart
fcm's Avatar
When you say, car does not start, do you mean it cranks, [turns over] but will not start, or do you mean it will not even crank?
You will have to "open" the ign switch to see if there is a problem or use a test light on the output leads to see if they have power when they are supposed to... http://techauto.awardspace.com/ignitionswitch.html 94
fcm is offline   Reply With Quote
Old 06-23-2011, 02:07 PM   #8
Sorry to bother you, but i saw your post here and was wondering if you could help me on my post since we are having the issue you were asking OP about. I opened up a new thread. Thank you
amoeba2315 is offline   Reply With Quote
Old 03-19-2016, 06:08 PM   #9
Default 96 Honda Accord starts then stalls
Quote:
Josh Healion is offline   Reply With Quote
Old 03-27-2016, 04:50 AM   #10
One easy way to test your ignition, is if the car starts, and continues to run while you HOLD THE KEY IN START the ignition is in fact bad. First of all though, turn the key and see if the check engine light turns off. If it doesn't the problem is your ECU. Now if the CEL (check engine light) turns off, and you dont hear your fuel pump, its probably your fuel pump relay located on the driver side, behind the dashboard.
trm4life is offline   Reply With Quote
Old 11-16-2016, 11:24 AM   #11
Between a worn cylinder, gummed up cylinder tabs, and bad switch, I just replaced the entire ignition assembly on my 2000 Odyssey. Here's a detailed write-up of the process:Replace Ignition Assembly on a 2000 Honda Odyssey
As for the switch itself, burnt residue from arcing across the contacts may coat the contact surfaces leading to intermittent completion of the start circuit. Judging from the wire gauge and soldering job on the switch, there's a butt-load of current going through that thing:
The black stuff on the rag was wiped off the metal contact surfaces within this switch.
Detail of the precipitated carbon smoke on the points cap of the switch:Carbon crap build-up within the ignition switch.Replacing JUST the switch requires that you know your way around a high current solder job. BTW....i couldn't figure out any easy way to replace just the cylinder, despite taking apart the entire thing on my work bench.
DickBean is offline   Reply With Quote
Where can I buy only the electrical switch and wires for my ignition? philztheone Honda Civic / Del Sol (1992 - 2000) 9 03-21-2016 05:44 AM
91 Honda Civic Si Not Starting mouab18c1 Honda CRX / EF Civic (1988 - 1991) 4 02-13-2016 07:30 PM
Help ignition problems David451 Introduce Yourself 0 08-26-2015 05:37 PM
Ignition switch bad??? slow_sihatch Tech / Misc 2 07-29-2015 04:11 PM
Alarm Ignition wire help gillman331 Honda Civic / Del Sol (1992 - 2000) 4 03-23-2015 06:44 PM
Tags
1993, 2003, accord, bad, civic, honda, igition, ignition, integra, recall, signs, starter, switch, symptom, symptoms, tech, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
